[Qgis-developer] Spatial queries plugin should ignore very small intersections
Bernhard Ströbl
bernhard.stroebl at jena.de
Mon Jan 7 02:25:14 PST 2013
I made an eliminate tool (similar to ESRI's eliminate). It dissolves
common boundaries of selected polygons and adjacent polygons with either
largest area or largest common boundary. If you have multi polygons you
would need to transform them into single polygons beforehand. The
eliminate tool is part of fTools in current master.
Bernhard
Am 07.01.2013 11:18, schrieb Régis Haubourg:
> Thanks Sandro,
> so that means that you get multi polygons with very small polygons created
> when a auto-intersection is cleaned. I prefer that since it does not
> destroys existing node. I think qe should add another tool after the
> 'makevalide' tool to clean those artefacts based on a surface threshold.
> This is really hard to achieve for common end user, and those artefacts can
> be really numerous if datasets are not clean. They also will make it harder
> to edit a polygon manually, and will slow down spatial intersections.
> Anybody else needs such a tool?
