[Qgis-developer] python error after updating
matteo matteo.ghetta at gmail.com
Tue Jan 8 08:11:56 PST 2013
Hi guys,
I wrote the same problem on the qgis user list, but I think here is better.
I work with Ubuntu 12.04 and with the nightly repo. I updated my system
but running QGis I get this error:
Impossibile caricare PyQGIS.
Il supporto Python verrà disabilitato.
File "", line 1, in
ImportError: No module named qgis.core
Versione Python:
2.7.3 (default, Aug  1 2012, 05:27:35)
[GCC 4.6.3]
Versione di QGIS:
1.9.0-Master 'Master', exported
Percorso Python:
['/usr/share/qgis/python', '/home/matteo/.qgis//python',
'/home/matteo/.qgis//python/plugins', '/usr/share/qgis/python/plugins',
'/usr/lib/python2.7', '/usr/lib/python2.7/plat-linux2',
'/usr/lib/python2.7/lib-tk', '/usr/lib/python2.7/lib-old',
'/usr/lib/python2.7/lib-dynload',
'/usr/local/lib/python2.7/dist-packages',
'/usr/lib/python2.7/dist-packages',
'/usr/lib/python2.7/dist-packages/PIL',
'/usr/lib/python2.7/dist-packages/gst-0.10',
'/usr/lib/python2.7/dist-packages/gtk-2.0',
'/usr/lib/pymodules/python2.7',
'/usr/lib/python2.7/dist-packages/ubuntu-sso-client',
'/usr/lib/python2.7/dist-packages/ubuntuone-client',
'/usr/lib/python2.7/dist-packages/ubuntuone-control-panel',
'/usr/lib/python2.7/dist-packages/ubuntuone-couch',
'/usr/lib/python2.7/dist-packages/ubuntuone-installer',
'/usr/lib/python2.7/dist-packages/ubuntuone-storage-protocol',
'/usr/lib/python2.7/dist-packages/wx-2.8-gtk2-unicode']
And when updating I get
Configurazione di python-qgis-common
(1.9.0+git20130105+12d1a28~precise-ubuntugis1)...
Compiling /usr/share/qgis/python/plugins/GdalTools/tools/dialogSRS.py ...
SyntaxError: ('invalid syntax',
('/usr/share/qgis/python/plugins/GdalTools/tools/dialogSRS.py', 50, 5,
'  def proj4string(self):\n'))
pycentral: pycentral pkginstall: error byte-compiling files (525)
dpkg: errore nell'elaborare python-qgis-common (--configure):
  il sottoprocesso vecchio script di post-installation ha restituito lo
stato di errore 1
dpkg: problemi con le dipendenze impediscono la configurazione di
python-qgis:
  python-qgis dipende da python-qgis-common (=
1.9.0+git20130105+12d1a28~precise-ubuntugis1), ma:
   Il pacchetto python-qgis-common non è ancora configurato.
dpkg: errore nell'elaborare python-qgis (--configure):
  problemi con le dipendenze - lasciato non configurato
Segnalazione apport non scritta poiché il messaggio di errore indica la
presenza di un fallimento precedente.
  Si sono verificati degli errori nell'elaborazione:
  python-qgis-common
  python-qgis
E: Sub-process /usr/bin/dpkg returned an error code (1)
So I looked into the file
https://github.com/qgis/Quantum-GIS/blob/master/python/plugins/GdalTools/tools/dialogSRS.py
and at line 48 I noticed that
return  str(self.selector.selectedAuthId())
has double brackets. Can be this the syntax problem?
I hope so because I need to use some plugins of QGIS...
Cheers
Matteo
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20130108/74850227/attachment-0001.html>
