[Qgis-developer] python error after updating
Salvatore Larosa
lrssvtml at gmail.com
Tue Jan 8 09:12:36 PST 2013
Hi Matteo,
the problem has already been fixed in master branch, so what you have to do
is wait for the next nightly or compile the master version :-)
You could also change that line in dialogSRS.py as you mentioned to get it
working!
Regards,
-SL
Il giorno 08/gen/2013 17:12, "matteo" <matteo.ghetta at gmail.com> ha scritto:
> Hi guys,
> I wrote the same problem on the qgis user list, but I think here is
better.
> I work with Ubuntu 12.04 and with the nightly repo. I updated my system
but running QGis I get this error:
> Impossibile caricare PyQGIS.
> Il supporto Python verrà disabilitato.
> Traceback (most recent call last):
> File "", line 1, in
> ImportError: No module named qgis.core
> Versione Python:
> 2.7.3 (default, Aug 1 2012, 05:27:35)
> [GCC 4.6.3]
> Versione di QGIS:
> 1.9.0-Master 'Master', exported
> Percorso Python:
> ['/usr/share/qgis/python', '/home/matteo/.qgis//python',
'/home/matteo/.qgis//python/plugins', '/usr/share/qgis/python/plugins',
'/usr/lib/python2.7', '/usr/lib/python2.7/plat-linux2',
'/usr/lib/python2.7/lib-tk', '/usr/lib/python2.7/lib-old',
'/usr/lib/python2.7/lib-dynload', '/usr/local/lib/python2.7/dist-packages',
'/usr/lib/python2.7/dist-packages', '/usr/lib/python2.7/dist-packages/PIL',
'/usr/lib/python2.7/dist-packages/gst-0.10',
'/usr/lib/python2.7/dist-packages/gtk-2.0', '/usr/lib/pymodules/python2.7',
'/usr/lib/python2.7/dist-packages/ubuntu-sso-client',
'/usr/lib/python2.7/dist-packages/ubuntuone-client',
'/usr/lib/python2.7/dist-packages/ubuntuone-control-panel',
'/usr/lib/python2.7/dist-packages/ubuntuone-couch',
'/usr/lib/python2.7/dist-packages/ubuntuone-installer',
'/usr/lib/python2.7/dist-packages/ubuntuone-storage-protocol',
'/usr/lib/python2.7/dist-packages/wx-2.8-gtk2-unicode']
> And when updating I get
> Configurazione di python-qgis-common
(1.9.0+git20130105+12d1a28~precise-ubuntugis1)...
> Compiling /usr/share/qgis/python/plugins/GdalTools/tools/dialogSRS.py ...
> SyntaxError: ('invalid syntax',
('/usr/share/qgis/python/plugins/GdalTools/tools/dialogSRS.py', 50, 5, '
def proj4string(self):\n'))
> pycentral: pycentral pkginstall: error byte-compiling files (525)
> dpkg: errore nell'elaborare python-qgis-common (--configure):
> il sottoprocesso vecchio script di post-installation ha restituito lo
stato di errore 1
> dpkg: problemi con le dipendenze impediscono la configurazione di
python-qgis:
> python-qgis dipende da python-qgis-common (=
1.9.0+git20130105+12d1a28~precise-ubuntugis1), ma:
> Il pacchetto python-qgis-common non è ancora configurato.
> dpkg: errore nell'elaborare python-qgis (--configure):
> problemi con le dipendenze - lasciato non configurato
> Segnalazione apport non scritta poiché il messaggio di errore indica la
presenza di un fallimento precedente.
> Si sono verificati degli errori nell'elaborazione:
> python-qgis-common
> python-qgis
> E: Sub-process /usr/bin/dpkg returned an error code (1)
> So I looked into the file
https://github.com/qgis/Quantum-GIS/blob/master/python/plugins/GdalTools/tools/dialogSRS.pyand
at line 48 I noticed that
> return str(self.selector.selectedAuthId())
> has double brackets. Can be this the syntax problem?
> I hope so because I need to use some plugins of QGIS...
> Cheers
> Matteo
> Qgis-developer mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20130108/4e745028/attachment.html>
