[Qgis-developer] Mac OS X 10.6, master version, sextante problem and solution (Python 2.6.x)
Marco Bernasocchi
marco at bernawebdesign.ch
Mon Jan 14 03:58:45 PST 2013
Victor, maybe of interest, regarding this, QGIS 1.7.4 on windows ships
with python 2.5 [0]
ciao
[0] https://github.com/AIFDR/inasafe/issues/341#issuecomment-9404357
On 01/13/2013 11:01 PM, Victor Olaya wrote:
> That sounds like OK to me, but I do not know the policy for adding new
> libraries in QGIS, since I haven't added any new one (SEXTANTE just
> uses the ones already included in QGIS). Alex might know more about
> it. Anyway, if it can be included, I would prefer it, since that would
> make it easier for all users to have a functional SEXTANTE without
> problems
> Regards
> 2013/1/13 Larry Shaffer <larrys at dakotacarto.com>:
>> Hi Gene,
>> On Sun, Jan 13, 2013 at 1:09 AM, gene <martin.laloux at gmail.com> wrote:
>>> I had a problem with the sextante module in the last master version of
>>> http://qgis.dakotacarto.com/ <http://qgis.dakotacarto.com/> . The Python
>>> module *importlib* is not present in a version of Python prior to 2.7
>>> The solution ?
>>> Install importlib <http://pypi.python.org/pypi/importlib/> , which is a
>>> backport of the importlib.import_module() from Python 2.7
>> Thanks for looking into this. I checked out the backported module and it is
>> quite simple. I should be able to add it to the bundled QGIS master version
>> for Snow Leopard (via the nightly build script, after the app is built, not
>> as part of the CMake build setup).
>> I should have time to do that on Monday morning. Once part of the bundled
>> app, I'll test it locally, but would appreciate if you can test it as well.
>> I'll post to the list again when it is ready.
>> That module could (should?) be added directly to the SEXTANTE plugin, since
>> it is Python 2.6 related, and not specific to Mac OS X 10.6. Could you draft
>> an issue on the tracker for its inclusion in SEXTANTE? (I have directly Cc'd
>> victor and alex on this as well.)
>> Regards,
>> Larry
>>> View this message in context:
>>> http://osgeo-org.1560.n6.nabble.com/Mac-OS-X-10-6-master-version-sextante-problem-and-solution-Python-2-6-x-tp5027133.html
>>> Sent from the Quantum GIS - Developer mailing list archive at Nabble.com.
>>> Qgis-developer mailing list
>>> Qgis-developer at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
Marco Bernasocchi
http://opengis.ch
