[Qgis-developer] Mac OS X 10.6, master version, sextante problem and solution (Python 2.6.x)
Victor Olaya
volayaf at gmail.com
Sun Jan 13 14:01:56 PST 2013
That sounds like OK to me, but I do not know the policy for adding new
libraries in QGIS, since I haven't added any new one (SEXTANTE just
uses the ones already included in QGIS). Alex might know more about
it. Anyway, if it can be included, I would prefer it, since that would
make it easier for all users to have a functional SEXTANTE without
problems
Regards
2013/1/13 Larry Shaffer <larrys at dakotacarto.com>:
> Hi Gene,
> On Sun, Jan 13, 2013 at 1:09 AM, gene <martin.laloux at gmail.com> wrote:
>> I had a problem with the sextante module in the last master version of
>> http://qgis.dakotacarto.com/ <http://qgis.dakotacarto.com/> . The Python
>> module *importlib* is not present in a version of Python prior to 2.7
>> The solution ?
>> Install importlib <http://pypi.python.org/pypi/importlib/> , which is a
>> backport of the importlib.import_module() from Python 2.7
> Thanks for looking into this. I checked out the backported module and it is
> quite simple. I should be able to add it to the bundled QGIS master version
> for Snow Leopard (via the nightly build script, after the app is built, not
> as part of the CMake build setup).
> I should have time to do that on Monday morning. Once part of the bundled
> app, I'll test it locally, but would appreciate if you can test it as well.
> I'll post to the list again when it is ready.
> That module could (should?) be added directly to the SEXTANTE plugin, since
> it is Python 2.6 related, and not specific to Mac OS X 10.6. Could you draft
> an issue on the tracker for its inclusion in SEXTANTE? (I have directly Cc'd
> victor and alex on this as well.)
> Regards,
> Larry
>> View this message in context:
>> http://osgeo-org.1560.n6.nabble.com/Mac-OS-X-10-6-master-version-sextante-problem-and-solution-Python-2-6-x-tp5027133.html
>> Sent from the Quantum GIS - Developer mailing list archive at Nabble.com.
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
