[Qgis-developer] Problems using QgsGeometryAnalyzer.simplify() on Mac OS?
Nathan Woodrow
madmanwoo at gmail.com
Wed Jan 23 21:16:23 PST 2013
Well the arg should be ogr as it is using the ogr driver.
I'm just wondering if its not loading the providers. Do you get any
console output when you run your script.
Sent from some fancy phone looking thingo
Sent: 24/01/2013 2:56 PM
To: qgis-developer at lists.osgeo.org
Subject: Re: [Qgis-developer] Problems using
It returns false when I try passing either "kml" or "ogr" as the importer.
Because I get the same result in the console with
>>> layer = QgsVectorLayer("/Users/[me]/wkt2/kml/ar-02.kml","ar","kml")
This leads me to think it is a simple file location problem, but I am
providing the direct path to the file. Is there another path variable I
need to set?
View this message in context:
http://osgeo-org.1560.n6.nabble.com/Problems-using-QgsGeometryAnalyzer-simplify-on-Mac-OS-tp5029433p5029437.html
Sent from the Quantum GIS - Developer mailing list archive at Nabble.com.
Qgis-developer mailing list
Qgis-developer at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/qgis-developer
