[Qgis-developer] OpenLayers plugin release and Python API breaks
Alexander Bruy
alexander.bruy at gmail.com
Thu Jan 24 04:32:54 PST 2013
Hi Pirmin,
as I can see in API docs (using your link) there is a note:
Note:
This method is deprecated since QGIS 1.8, you should use
addMapLayers rather.
Regarding PyQGIS CookBook I agree that it should be updated
to reflect all API changes. But I think it is better to update it after
merging new_vector_api branch
2013/1/24 Pirmin Kalberer <pi_ml at sourcepole.com>:
> Hi Alex,
> Am Donnerstag, 24. Januar 2013, 10.40:00 schrieb Alexander Bruy:
>> please note that most of this methods were marked as deprecated for
>> a long time. Some of them are deprecated since QGIS 1.6 or even
>> earlier.
> Where exactly is it marked as deprecated? At least not in the API docs [1].
> And the current PyQGIS cookbook shows it as an example [2].
> I'm only asking for a more user friendly way than having to read the C++
> source code first.
> Pirmin
> [1]
> http://qgis.org/api/1.8/classQgsMapLayerRegistry.html#a06a1339cd757608a61e3899a27f39e8a
> [2] http://www.qgis.org/pyqgis-cookbook/loadlayer.html#map-layer-registry
Alexander Bruy
