[Qgis-developer] Ubuntu 12.04 64 bit - QGIS 1.8.0 - Segmentation Fault
Matthias Kuhn
matthias.kuhn at gmx.ch
Fri Jan 25 05:44:46 PST 2013
Hi Mihis,
Did you specify to run the qgis binary? In QtCreator, go to Projects =>
Run Settings and check that the Run configuration is set to qgis.
Regards,
Matthias
On 01/25/2013 02:41 PM, Mihis wrote:
> Hi.
> I have built QGIS 1.8.0 (final release) from source code in Qt Creator by
> opening CMake project file (CMakeLists.txt). Platform - Ubuntu 64 bit. The
> built finished without errors. All build dependencies were installed
> according the following instructions
> https://github.com/qgis/Quantum-GIS/blob/master/INSTALL. However, when I
> start program either in release or in debug mode the following runtime error
> occurs:
> Starting .../qtcreator-build/output/lib/qgis/grass/modules/qgis.d.rast...
> The program has unexpectedly finished.
> .../qtcreator-build/output/lib/qgis/grass/modules/qgis.d.rast exited with
> code 0
> Does anybody have ideas where the problem is?
> View this message in context: http://osgeo-org.1560.n6.nabble.com/Ubuntu-12-04-64-bit-QGIS-1-8-0-Segmentation-Fault-tp5029861.html
> Sent from the Quantum GIS - Developer mailing list archive at Nabble.com.
> Qgis-developer mailing list
