[Qgis-developer] Ubuntu 12.04 64 bit - QGIS 1.8.0 - Segmentation Fault
Mihis
mihis.sakh at gmail.com
Fri Jan 25 05:41:06 PST 2013
Hi.
I have built QGIS 1.8.0 (final release) from source code in Qt Creator by
opening CMake project file (CMakeLists.txt). Platform - Ubuntu 64 bit. The
built finished without errors. All build dependencies were installed
according the following instructions
https://github.com/qgis/Quantum-GIS/blob/master/INSTALL. However, when I
start program either in release or in debug mode the following runtime error
occurs:
Starting .../qtcreator-build/output/lib/qgis/grass/modules/qgis.d.rast...
The program has unexpectedly finished.
.../qtcreator-build/output/lib/qgis/grass/modules/qgis.d.rast exited with
code 0
Does anybody have ideas where the problem is?
View this message in context: http://osgeo-org.1560.n6.nabble.com/Ubuntu-12-04-64-bit-QGIS-1-8-0-Segmentation-Fault-tp5029861.html
Sent from the Quantum GIS - Developer mailing list archive at Nabble.com.
