[Qgis-developer] Labeling: data-defined fields shifted after new vector API?
Matthias Kuhn
matthias.kuhn at gmx.ch
Mon Jan 28 01:35:51 PST 2013
Note:
This could be related to the following fix for a failed test:
https://github.com/qgis/Quantum-GIS/pull/405
I issued a pull request, because the test didn't fail due to a problem
in diagram itself.
It might be good to implement a test for this specific issue as well.
Would be easy to implement based on the diagram test.
Regards Matthias
On 01/28/2013 10:30 AM, Andreas Neumann wrote:
> Hi,
> In some of my projects data-defined values for labeling (like
> font-color, rotation fields) are now failing - the order of the column
> assignments are shifted by one column. Perhaps the new Vector API is
> the cause? My data comes from the Postgis data provider. I am testing
> in the version 74ace4ad21 from January 27.
> I checked with an older version from last week (the version starting
> with 298f0c000e from January 25) and the labeling is still working ok.
> Martin or Marco - could either one of you please have a look what may
> be causing this problem?
> Thanks,
> Andreas
