[Qgis-developer] Labeling: data-defined fields shifted after new vector API?
Andreas Neumann
a.neumann at carto.net
Mon Jan 28 01:30:28 PST 2013
In some of my projects data-defined values for labeling (like
font-color, rotation fields) are now failing - the order of the column
assignments are shifted by one column. Perhaps the new Vector API is the
cause? My data comes from the Postgis data provider. I am testing in the
version 74ace4ad21 from January 27.
I checked with an older version from last week (the version starting
with 298f0c000e from January 25) and the labeling is still working ok.
Martin or Marco - could either one of you please have a look what may
be causing this problem?
Thanks,
Andreas
Andreas Neumann
Böschacherstrasse 10A
8624 Grüt (Gossau ZH)
Switzerland
