[Qgis-developer] Problems with lizmapclient
kimaidou
kimaidou at gmail.com
Wed Jan 30 05:02:13 PST 2013
Hi Paolo,
Sorry for the delay, I am a bit busy right now :)
I will try to answer you questions :
* Are you trying to install lizmap web client on a Windows machine or a
Linux box ?
* The zip file of the last version is here :
http://demo.3liz.com/download/lizmap-web-client-2.4.1.zip
I should add the direct link in the wiki page. For now it is too "geek"
with shell variables, etc.
* The chmod and chown commands are necessary to allow Lizmap script to be
run by Apache user. In a linux box, there is no need to give specific
rights to the folders containing the qgis projects and data. On windows
boxes, I have to try it...
* I totally agree with the need to move from redmine to rst, but I just did
not dare to ask the QGIS team to include Lizmap documentation in QGIS
documentation. I would be very happy to use RST instead. I will begin the
rewrite. By the way, there is a Redmine plugin allowing to use RST instead
of the redmine syntax for all the redmine features (wiki, issues). See [1]
I think it could help a lot to move to RST inside redmine too. (big work
though : migrate from existing syntax into rst, with tools like this one or
command line [2]
[1] http://glacialis.postmodo.com/posts/zyd1ig
[2] http://johnmacfarlane.net/pandoc/try/
* New API : thanks for letting me know. The correction will be effective in
the next release
Thanks for your feedbacks !
Michael
2013/1/28 Paolo Cavallini <cavallini at faunalia.it>
> Il 28/01/2013 18:22, Paolo Cavallini ha scritto:
> Il 28/01/2013 17:13, Paolo Cavallini ha scritto:
> Hi all.
> It seems that instructions on:
> http://hub.qgis.org/wiki/lizmapwebclient/Installation_en
> are a bit outdated, e.g. the zip does not seem available from the link
> shown.
> Once installed, I get a pink square over a part of the area: is this a
> known problem?Anything to be done?
> Found a possible bug: when creating a project, if the target dir is not
> writable, no error message is displayed, so the user may think
> everything is ok.
> sorry, I think I misunderstood the command, and shoud be ok.
> suggestion for the outdated wiki page: write the readme in rst, remove
> the wiki page, and add the rst to the general documentation and to the
> new web site.
> On the other hand, the plugin should be updated to the new API:
> Traceback (most recent call last):
> File "/home/paolo/.qgis//python/plugins/lizmap/lizmap.py", line 1418, in
> warnOnClose
> self.writeProjectConfigFile()
> File "/home/paolo/.qgis//python/plugins/lizmap/lizmap.py", line 726, in
> pSrs = mc.mapRenderer().destinationSrs()
> AttributeError: 'QgsMapRenderer' object has no attribute 'destinationSrs'
> All the best.
> Paolo Cavallini - Faunaliawww.faunalia.eu
> Full contact details at www.faunalia.eu/pc
> Nuovi corsi QGIS e PostGIS: http://www.faunalia.it/calendario
> Qgis-developer mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20130130/820d1a62/attachment-0001.html>
