[Qgis-developer] SRS DB maintenance
Werner Macho
werner.macho at gmail.com
Thu Jul 4 00:19:02 PDT 2013
*lol*
I knew that that was coming ..
And I also knew that you surely already took a look on it .. but as I
did not know what has already been looked at .. I took the easiest
thought that I had ..
I also know that it is not easy .. but .. as Radim also said .. there
are problems .. somehow ..
But thanks for the insight into crssync and the noupdate field .. :(
.. crazy stuff ..
And .. if you could implement a DWIM UI .,. I would also like to see
that in a lot of other software :)
regards
Werner
On Thu, Jul 4, 2013 at 8:59 AM, Jürgen E. <jef at norbit.de> wrote:
> Hi Werner,
> On Thu, 04. Jul 2013 at 08:35:42 +0200, Werner Macho wrote:
>> As I had some problems with non existing EPSG Codes in the srs.db
>> lately too .. I support Radim here ..
>> It seem's that something is going wroing here .. While most of the
>> world is covered not all EPSGs are available or being overwritten ..
>> Isn't there an official "latest" database that we can just take? Or
>> try to make it easy for the user to update the db if connected to the
>> internet sync db on QGIS start or something like that?
> Brilliant. Why didn't we think of that before - and we can also reduce the
> cluttered QGIS UI to a single DWIM[1] button while we're at it. ;)
> 7805af3cf introduces a noupdate field in tbl_srs, that is set to 1 for the
> mentioned CRSes. And crssync doesn't update or delete records marked like
> that. But that flag should probably tracked somehow and set to 0 eventually,
> when the CRSes get corrected in/introduced to geotiff/GDAL/proj.4.
> Jürgen
> [1] http://en.wikipedia.org/wiki/DWIM
> Jürgen E. Fischer norBIT GmbH Tel. +49-4931-918175-31
> Dipl.-Inf. (FH) Rheinstraße 13 Fax. +49-4931-918175-50
> Software Engineer D-26506 Norden http://www.norbit.de
> committ(ed|ing) to QGIS IRC: jef on FreeNode
> norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
> Rheinstrasse 13, 26506 Norden
> GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
> Qgis-developer mailing list
