[Qgis-developer] [Qgis-user] QGIS installation problem with Mac OSX 10.8.4 and some Qt4 Modules
William Kyngesburye woklist at kyngchaos.com
Sat Jul 6 09:54:49 PDT 2013
Could be a small problem with SIP 4.14.7 and Mt Lion (sorry, I'm on Lion, but it's annoying that a minor update is sensitive to system version).  If 4.14.6 works, that's OK, but good to know for updating the INSTALL doc.
What version of Xcode do you have?
On Jul 6, 2013, at 11:46 AM, Marcel Stadelmann wrote:
> there was a PyQt4 folder, which I deleted, but it didn' help. Also compiling without -j 8 did not help.
> I tried now with sip-4.14.6 and it worked. I could successfully install PyQt 4.10.2. I will later continue the QGIS installation. Thank you very much for your help.
> Marcel
> Am 06.07.2013 um 18:15 schrieb William Kyngesburye <woklist at kyngchaos.com>:
>> make sure to delete the corresponding /usr/local/lib/python2.7/site-packages/sipconfig.py file, just to make sure.  And any other sip and pyqt files and folders left there.
>> Also, try compiling without the -j 8 flag (it will take a lot longer to compile), sometimes too much parallel compilation can confuse make.  Or use a smaller number for -j.
>> If you still get the pyqt compile error, it's beyond me, might want to try the pyqt mailing list.
>> On Jul 6, 2013, at 11:07 AM, Marcel Stadelmann wrote:
>>> yeah, there was an old sipconfig.pyc in /usr/local/lib/python2.7/site-packages/ (the results of your instructions see below). After deleting sipconfig.pyc,  the python configuration passed, but then i got stacked while "make -j 8". The following failures appeared:
>>> g++ -c -pipe -fPIC -O2 -Wall -W -DNDEBUG -DSIP_PROTECTED_IS_PUBLIC -Dprotected=public -DQT_NO_DEBUG -DQT_CORE_LIB -I. -I/Users/Marcello/Downloads/PyQt-mac-gpl-4.10.2/qpy/QtCore -I/usr/local/include -I/System/Library/Frameworks/Python.framework/Versions/2.7/include/python2.7 -I/mkspecs/macx-g++ -I/Library/Frameworks/QtCore.framework/Headers -I/usr/include -F/Users/Marcello/Downloads/PyQt-mac-gpl-4.10.2/qpy/QtCore -F/Library/Frameworks -o sipQtCoreQXmlStreamNamespaceDeclaration.o sipQtCoreQXmlStreamNamespaceDeclaration.cpp
>>> /Users/Marcello/Downloads/PyQt-mac-gpl-4.10.2/QtCore/sipQtCoreQPyNullVariant_5.cpp:301: error: too many initializers for ‘sipClassTypeDef’
>>> make[1]: *** [sipQtCoreQPyNullVariant_5.o] Error 1
>>> make[1]: *** Waiting for unfinished jobs....
>>> /Users/Marcello/Downloads/PyQt-mac-gpl-4.10.2/QtCore/sipQtCoreQXmlStreamReader.cpp:1856: error: too many initializers for ‘sipClassTypeDef’
>>> /Users/Marcello/Downloads/PyQt-mac-gpl-4.10.2/QtCore/sipQtCoreQXmlStreamWriter.cpp:1198: error: too many initializers for ‘sipClassTypeDef’
>>> /Users/Marcello/Downloads/PyQt-mac-gpl-4.10.2/QtCore/sipQtCoreQXmlStreamEntityResolver.cpp:282: error: too many initializers for ‘sipClassTypeDef’
>>> make[1]: *** [sipQtCoreQXmlStreamReader.o] Error 1
>>> make[1]: *** [sipQtCoreQXmlStreamWriter.o] Error 1
>>> make[1]: *** [sipQtCoreQXmlStreamEntityResolver.o] Error 1
>>> /Users/Marcello/Downloads/PyQt-mac-gpl-4.10.2/QtCore/sipQtCoreQXmlStreamEntityDeclaration.cpp:409: error: too many initializers for ‘sipClassTypeDef’
>>> /Users/Marcello/Downloads/PyQt-mac-gpl-4.10.2/QtCore/sipQtCoreQXmlStreamNotationDeclaration.cpp:349: error: too many initializers for ‘sipClassTypeDef’
>>> make[1]: *** [sipQtCoreQXmlStreamEntityDeclaration.o] Error 1
>>> /Users/Marcello/Downloads/PyQt-mac-gpl-4.10.2/QtCore/sipQtCoreQXmlStreamNamespaceDeclaration.cpp:341: error: too many initializers for ‘sipClassTypeDef’
>>> make[1]: *** [sipQtCoreQXmlStreamNotationDeclaration.o] Error 1
>>> make[1]: *** [sipQtCoreQXmlStreamNamespaceDeclaration.o] Error 1
>>> make: *** [all] Error 2
>>> Am 06.07.2013 um 17:16 schrieb William Kyngesburye <woklist at kyngchaos.com>:
>>>> yeah, something for the old sip was not deleted...  try this:
>>>> start python2.7, then:
>>>> import sipconfig
>>>> sipconfig.__file__
>>> Marcels-iMac:PyQt-mac-gpl-4.10.2 Marcello$ python
>>> Python 2.7.2 (default, Oct 11 2012, 20:14:37)
>>> [GCC 4.2.1 Compatible Apple Clang 4.0 (tags/Apple/clang-418.0.60)] on darwin
>>> Type "help", "copyright", "credits" or "license" for more information.
>>>>>> import sipconfig
>>>>>> sipconfig.__file__
>>> '/usr/local/lib/python2.7/site-packages/sipconfig.pyc'
>>>> This should tell you where pyqt configure is finding sip.  You can also get the details of that sipconfig:
>>>> from sipconfig import _pkg_config
>>>> _pkg_config
>>>>>> _pkg_config
>>> {'default_mod_dir': '/Library/Python/2.7/site-packages', 'default_bin_dir': '/System/Library/Frameworks/Python.framework/Versions/2.7/bin', 'platform': 'macx-g++', 'sip_version_str': '4.14.6', 'universal': '', 'sip_version': 265734, 'sip_config_args': '--destdir=/usr/local/Cellar/sip/4.14.6/lib/python2.7/site-packages --bindir=/usr/local/Cellar/sip/4.14.6/bin --incdir=/usr/local/Cellar/sip/4.14.6/include --sipdir=/usr/local/share/sip', 'default_sip_dir': '/usr/local/share/sip', 'sip_mod_dir': '/usr/local/Cellar/sip/4.14.6/lib/python2.7/site-packages', 'sip_bin': '/usr/local/Cellar/sip/4.14.6/bin/sip', 'sip_inc_dir': '/usr/local/Cellar/sip/4.14.6/include', 'py_conf_inc_dir': '/System/Library/Frameworks/Python.framework/Versions/2.7/include/python2.7', 'deployment_target': '', 'py_lib_dir': '/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/config', 'arch': '', 'py_version': 132866, 'py_inc_dir': '/System/Library/Frameworks/Python.framework/Versions/2.7/include/python2.7'}
>> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
>> http://www.kyngchaos.com/
>> "History is an illusion caused by the passage of time, and time is an illusion caused by the passage of history."
>> - Hitchhiker's Guide to the Galaxy
Earth: "Mostly harmless"
- revised entry in the HitchHiker's Guide to the Galaxy
