[Qgis-developer] CyberTracker integration
Tim Sutton
lists at linfiniti.com
Sun Jul 7 05:38:40 PDT 2013
Hi Justin
Having a cybertracker sequence generator in QGIS would be great. In general
for open source the way to go is to build something that solves your own
needs and then put it out there for others to use and contribute to. You
will probably get much more useful and directed feedback if people have
something (even an initial prototype) to play with that they can then kick
the tyres and give you pointers on what additions would make it more useful.
Regards
Tim
On Sun, Jul 7, 2013 at 8:07 AM, Justin Steventon <justin at steventon.com>wrote:
> That’s true, I missed the concept of a form in the description on the
> site. ****
> My interest is in a rich, user friendly data capture experience,
> especially for cases where the field user is not a QGIS user and may not be
> able to read or write. Our studies indicate that this is also a more
> efficient way to capture data for literate users. Over the years we’ve
> rolled our own mini-GIS for the desktop, but the scalability of this
> approach is clearly limited. Since we’re a non-profit and in the process of
> opening our code, it makes sense to leverage an existing system. Of the
> solutions I have investigated, QGIS seems most aligned at the technical
> level.****
> We do bring some interesting work to the table. Our client supports
> Windows Mobile and Android and has a large library of customizable UI
> components which can capture many different data types, including images
> and sound. There is also support for timer tracks and a field map.****
> I’m pretty new to the Open Source community, so apologies if this is off.
> I’m probably going about this all wrong.****
> Cheers,****
> -Justin****
> *From:* Nathan Woodrow [mailto:madmanwoo at gmail.com]
> *Sent:* Saturday, July 6, 2013 10:24 PM
> *To:* Justin Steventon
> *Cc:* qgis-developer at lists.osgeo.org
> *Subject:* Re: [Qgis-developer] CyberTracker integration****
> My project isn't about putting QGIS onto PDA. QGIS doesn't run on PDAs
> and I doubt it ever will.****
> QMap is meant to be a field collection version of QGIS.****
> - Nathan****
> On Sun, Jul 7, 2013 at 3:13 PM, Justin Steventon <justin at steventon.com>
> wrote:****
> Thanks Jürgen,****
> I see Nathan’s project is really about putting a stripped down version of
> QGIS onto a PDA. Nevertheless, it’s impressive.****
> CyberTracker is designed more as a data capture conduit – highly
> customizable UI (via XML) that can be used even by low-literate folks.
> Integration with QGIS would be great.****
> If anyone is interested in a collaboration, please let me know.****
> Cheers,****
> -Justin****
> Qgis-developer mailing list
> http://lists.osgeo.org/mailman/listinfo/qgis-developer****
Tim Sutton - QGIS Project Steering Committee Member (Release Manager)
Please do not email me off-list with technical
support questions. Using the lists will gain
more exposure for your issues and the knowledge
surrounding your issue will be shared with all.
Irc: timlinux on #qgis at freenode.net
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20130707/7d4aec20/attachment.html>
