[Qgis-developer] SEXTANTE adaptation to new SAGA version
samuelmesa at gmail.com
Mon Jul 8 10:00:10 PDT 2013
I updated the latest versions of QGIS (Master) and SAGA GIS (2.1.0) on Arch
Linux, however I have seen errors when running commands of SAGA from Sextante,
since it has been removed the prefix "lib" in the SAGA modules. The
solution has been to remove the prefix "lib" (lines 240, 307 and 356) from
file SagaAlgorithm.py [1].
I think this information is useful for Linux users who start using the
latest version of SAGA GIS.
[1]
https://github.com/qgis/Quantum-GIS/blob/master/python/plugins/sextante/saga/SagaAlgorithm.py
Regards,
Samuel Mesa.
2013/7/6 samuelmesa at gmail.com <samuelmesa at gmail.com>
> Thanks Victor for the great work with SEXTANTE. In Arch Linux distribution is
> available the SAGA GIS v2.1.0 update to be installed from AUR repositories
> https://aur.archlinux.org/packages/saga-gis/
> Thanks,
> Samuel Mesa.
> 2013/7/4 Victor Olaya <volayaf at gmail.com>
>> Hi all
>> SAGA 2.1.0 has just been released. The current version of SEXTANTE in
>> master has been now adapted to work with SAGA 2.1.0, and raster
>> algorithms will not work with any other version. Please, update your
>> SAGA executables if using the latest master version, since now 2.1.0
>> is the target version.
>> The only algorithm adapted so far is the raster export one, which, for
>> SEXTANTE, was the most important one that had been modified, since it
>> blocks all other raster algorithms. Other algorithms might have
>> changed, but they are not adapted yet. If you find something that was
>> working before and now it doesn't, please report. Also, if there are
>> new algorithms, feel free to suggest them to be added to SEXTANTE as
>> well, describing their syntax, if possible, to help us do it.
>> Windows users, please notice that the Osgeo4W installer still ships
>> with SAGA 2.0.8, so you will need to install SAGA 2.1.0 manually and
>> change the SAGA path in SEXTANTE. This will be updated soon, so it's
>> just a temporary issue
>> Thanks for your help
>> Victor
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
> / v \
/ v \
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20130708/f9e56bfc/attachment.html>
