[Qgis-developer] SEXTANTE adaptation to new SAGA version
    Victor Olaya
    volayaf at gmail.com
    Mon Jul  8 10:59:16 PDT 2013
I wasn't aware of that change...but it is a big one, for sure.
Thanks for reporting it
I will change it
Cheers
VIctor
2013/7/8 samuelmesa at gmail.com <samuelmesa at gmail.com>:
> I updated the latest versions of QGIS (Master) and SAGA GIS (2.1.0) on Arch
> Linux, however I have seen errors when running commands of SAGA from
> Sextante, since it has been removed the prefix "lib" in the SAGA modules.
> The solution has been to remove the prefix "lib" (lines 240, 307 and 356)
> from file SagaAlgorithm.py [1].
> I think this information is useful for Linux users who start using the
> latest version of SAGA GIS.
> [1]
> https://github.com/qgis/Quantum-GIS/blob/master/python/plugins/sextante/saga/SagaAlgorithm.py
> Regards,
> Samuel Mesa.
> 2013/7/6 samuelmesa at gmail.com <samuelmesa at gmail.com>
>> Thanks Victor for the great work with SEXTANTE. In Arch Linux distribution
>> is available the SAGA GIS v2.1.0 update to be installed from AUR
>> repositories.
>> https://aur.archlinux.org/packages/saga-gis/
>> Thanks,
>> Samuel Mesa.
>> 2013/7/4 Victor Olaya <volayaf at gmail.com>
>>> Hi all
>>> SAGA 2.1.0 has just been released. The current version of SEXTANTE in
>>> master has been now adapted to work with SAGA 2.1.0, and raster
>>> algorithms will not work with any other version. Please, update your
>>> SAGA executables if using the latest master version, since now 2.1.0
>>> is the target version.
>>> The only algorithm adapted so far is the raster export one, which, for
>>> SEXTANTE, was the most important one that had been modified, since it
>>> blocks all other raster algorithms. Other algorithms might have
>>> changed, but they are not adapted yet. If you find something that was
>>> working before and now it doesn't, please report. Also, if there are
>>> new algorithms, feel free to suggest them to be added to SEXTANTE as
>>> well, describing their syntax, if possible, to help us do it.
>>> Windows users, please notice that the Osgeo4W installer still ships
>>> with SAGA 2.0.8, so you will need to install SAGA 2.1.0 manually and
>>> change the SAGA path in SEXTANTE. This will be updated soon, so it's
>>> just a temporary issue
>>> Thanks for your help
>>> Victor
>>> Qgis-developer mailing list
>>> Qgis-developer at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
>>    / v \
>    / v \
