[Qgis-developer] Toolbar and Panel defaults
Nathan Woodrow
madmanwoo at gmail.com
Wed Jul 10 16:13:15 PDT 2013
I think on the right is fine. To me that feels better that all the way over
on the left.
It's a real bugger that we can't make Qt dock the toolbars inside something
else, seems you are constrained to QMainWindow.
- Nathan
On Thu, Jul 11, 2013 at 9:05 AM, Larry Shaffer <larrys at dakotacarto.com>wrote:
> Hi Nathan,
> On Wed, Jul 10, 2013 at 4:51 PM, Nathan Woodrow <madmanwoo at gmail.com>wrote:
>> Having the nav toolbar on the side would be ideal if you could dock it on
>> the right side of the layers panel. I'm not a fan of having to go all the
>> way over the layer panel to access the navigation tools.
> That's a very good point. What about the Navigation toolbar on the right,
> with the Plugin toolbar filling the empty space at right on the first row
> of horizontal toolbars?
> Here's my reasoning. Nav tools are quickly accessible, and when a new user
> downloads/installs a plugin, there is already space to show it (assuming
> that plugin loads a tool button into the Plugins toolbar). Then the user
> can move toolbars to their liking.
> Any other ideas?
> [0] http://drive.dakotacarto.com/qgis/qgis_default_nav-tools-right.png
> Regards,
> Larry
> - Nathan
>> On Thu, Jul 11, 2013 at 8:49 AM, Larry Shaffer <larrys at dakotacarto.com>wrote:
>>> H Pirmin,
>>> On Wed, Jul 10, 2013 at 3:29 PM, Pirmin Kalberer <pi_ml at sourcepole.com>wrote:
>>>> Hi Jürgen,
>>>> Am Mittwoch, 10. Juli 2013, 08.38:38 schrieb Jürgen E. Fischer:
>>>> > On Tue, 09. Jul 2013 at 22:55:18 +0200, Pirmin Kalberer wrote:
>>>> > > Toolbars:
>>>> > > -Turn off Advanced Digitizing
>>>> > > -Move Label to second row
>>>> > > Panels:
>>>> > > -Turn on Layer order and Browser in a tabbed view with Layers
>>>> > > Print composer:
>>>> > > -Place all toolbars in one row
>>>> > In case anyone missed it: scripts/mkuidefaults.py produces
>>>> > src/app/ui_defaults.h from the current settings.
>>>> Didn't know that. Updated the script to support composer UI defaults.
>>> Couple of other ideas comments, too:
>>> * Currently there are no side toolbars by default. Many apps utilize the
>>> left side toolbar for critical tools. To me, such tools in a GIS app are
>>> the canvas navigation tools. So whenever I to an initial setup of QGIS, I
>>> always put the Map Navigation toolbar on the left.
>>> * Similarly, I always place the Plugins toolbar on the right side. There
>>> is currently a bug that sets that toolbar to not be shown on a default
>>> install (that should be fixed).
>>> I would like to hear feedback on those two suggestions for default side
>>> toolbars. Following your suggestions (and mine), the default window would
>>> look similar to this (on Mac) [0].
>>> +1 for removing Advanced Digitizing toolbar as a default, as all of the
>>> functions are available in the Edit menu already. If needed, the user can
>>> show that toolbar.
>>> Another major layout issue is what the layout looks like after turning
>>> on all core plugins [1]. Then, what it looks like when all those plugin
>>> toolbars are shown [2]. This needs some work.
>>> [0] http://drive.dakotacarto.com/qgis/qgis_default.png
>>> [1]
>>> http://drive.dakotacarto.com/qgis/qgis_default_core-plugins_no-extra-toolbars.png
>>> [2]
>>> http://drive.dakotacarto.com/qgis/qgis_default_core-plugins_with-toolbars.png
>>> Regards,
>>> Larry
>>>> > So updating it should be easy, once it's decides what should be the
>>>> default.
>>>> > Not sure if the data contains pixel coordinates and if the screen
>>>> resolution
>>>> > might therefore be an issue...
>>>> Let's try: https://github.com/qgis/Quantum-GIS/pull/710
>>>> Pirmin
>>>> Pirmin Kalberer
>>>> Sourcepole - Linux & Open Source Solutions
>>>> http://www.sourcepole.com
>>>> _______________________________________________
>>>> Qgis-developer mailing list
>>>> Qgis-developer at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20130711/8f3d85df/attachment.html>
