[Qgis-developer] Toolbar and Panel defaults
antoniolocandro
antoniolocandro at hotmail.com
Wed Jul 10 17:37:21 PDT 2013
I've never liked side bar tools but since I will be able to move it I wouldn't be unhappy if that's the default
Sent from Samsung tabletLarry Shaffer <larrys at dakotacarto.com> wrote:H Pirmin,
On Wed, Jul 10, 2013 at 3:29 PM, Pirmin Kalberer <pi_ml at sourcepole.com> wrote:
Hi Jürgen,
Am Mittwoch, 10. Juli 2013, 08.38:38 schrieb Jürgen E. Fischer:
> On Tue, 09. Jul 2013 at 22:55:18 +0200, Pirmin Kalberer wrote:
> > Toolbars:
> > -Turn off Advanced Digitizing
> > -Move Label to second row
> > Panels:
> > -Turn on Layer order and Browser in a tabbed view with Layers
> > Print composer:
> > -Place all toolbars in one row
> In case anyone missed it: scripts/mkuidefaults.py produces
> src/app/ui_defaults.h from the current settings.
Didn't know that. Updated the script to support composer UI defaults.
Couple of other ideas comments, too:
* Currently there are no side toolbars by default. Many apps utilize the left side toolbar for critical tools. To me, such tools in a GIS app are the canvas navigation tools. So whenever I to an initial setup of QGIS, I always put the Map Navigation toolbar on the left.
* Similarly, I always place the Plugins toolbar on the right side. There is currently a bug that sets that toolbar to not be shown on a default install (that should be fixed).
I would like to hear feedback on those two suggestions for default side toolbars. Following your suggestions (and mine), the default window would look similar to this (on Mac) [0].
+1 for removing Advanced Digitizing toolbar as a default, as all of the functions are available in the Edit menu already. If needed, the user can show that toolbar.
Another major layout issue is what the layout looks like after turning on all core plugins [1]. Then, what it looks like when all those plugin toolbars are shown [2]. This needs some work.
[0] http://drive.dakotacarto.com/qgis/qgis_default.png
[1] http://drive.dakotacarto.com/qgis/qgis_default_core-plugins_no-extra-toolbars.png
[2] http://drive.dakotacarto.com/qgis/qgis_default_core-plugins_with-toolbars.png
Regards,
Larry
> So updating it should be easy, once it's decides what should be the default.
> Not sure if the data contains pixel coordinates and if the screen resolution
> might therefore be an issue...
Let's try: https://github.com/qgis/Quantum-GIS/pull/710
Pirmin
Pirmin Kalberer
Sourcepole - Linux & Open Source Solutions
http://www.sourcepole.com
Qgis-developer mailing list
Qgis-developer at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20130710/3b289596/attachment.html>
