[Qgis-developer] Toolbar and Panel defaults
antoniolocandro
antoniolocandro at hotmail.com
Wed Jul 10 17:40:23 PDT 2013
Could we add the possibility to close toolbars by undocking them and hitting an x in the window
I prefer the right for navigation than left
Sent from Samsung tabletLarry Shaffer <larrys at dakotacarto.com> wrote:Hi Nathan,
On Wed, Jul 10, 2013 at 4:51 PM, Nathan Woodrow <madmanwoo at gmail.com> wrote:
Having the nav toolbar on the side would be ideal if you could dock it on the right side of the layers panel. I'm not a fan of having to go all the way over the layer panel to access the navigation tools.
That's a very good point. What about the Navigation toolbar on the right, with the Plugin toolbar filling the empty space at right on the first row of horizontal toolbars?
Here's my reasoning. Nav tools are quickly accessible, and when a new user downloads/installs a plugin, there is already space to show it (assuming that plugin loads a tool button into the Plugins toolbar). Then the user can move toolbars to their liking.
Any other ideas?
[0] http://drive.dakotacarto.com/qgis/qgis_default_nav-tools-right.png
Regards,
Larry
- Nathan
On Thu, Jul 11, 2013 at 8:49 AM, Larry Shaffer <larrys at dakotacarto.com> wrote:
H Pirmin,
On Wed, Jul 10, 2013 at 3:29 PM, Pirmin Kalberer <pi_ml at sourcepole.com> wrote:
Hi Jürgen,
Am Mittwoch, 10. Juli 2013, 08.38:38 schrieb Jürgen E. Fischer:
> On Tue, 09. Jul 2013 at 22:55:18 +0200, Pirmin Kalberer wrote:
> > Toolbars:
> > -Turn off Advanced Digitizing
> > -Move Label to second row
> > Panels:
> > -Turn on Layer order and Browser in a tabbed view with Layers
> > Print composer:
> > -Place all toolbars in one row
> In case anyone missed it: scripts/mkuidefaults.py produces
> src/app/ui_defaults.h from the current settings.
Didn't know that. Updated the script to support composer UI defaults.
Couple of other ideas comments, too:
* Currently there are no side toolbars by default. Many apps utilize the left side toolbar for critical tools. To me, such tools in a GIS app are the canvas navigation tools. So whenever I to an initial setup of QGIS, I always put the Map Navigation toolbar on the left.
* Similarly, I always place the Plugins toolbar on the right side. There is currently a bug that sets that toolbar to not be shown on a default install (that should be fixed).
I would like to hear feedback on those two suggestions for default side toolbars. Following your suggestions (and mine), the default window would look similar to this (on Mac) [0].
+1 for removing Advanced Digitizing toolbar as a default, as all of the functions are available in the Edit menu already. If needed, the user can show that toolbar.
Another major layout issue is what the layout looks like after turning on all core plugins [1]. Then, what it looks like when all those plugin toolbars are shown [2]. This needs some work.
[0] http://drive.dakotacarto.com/qgis/qgis_default.png
[1] http://drive.dakotacarto.com/qgis/qgis_default_core-plugins_no-extra-toolbars.png
[2] http://drive.dakotacarto.com/qgis/qgis_default_core-plugins_with-toolbars.png
Regards,
Larry
> So updating it should be easy, once it's decides what should be the default.
> Not sure if the data contains pixel coordinates and if the screen resolution
> might therefore be an issue...
Let's try: https://github.com/qgis/Quantum-GIS/pull/710
Pirmin
Pirmin Kalberer
Sourcepole - Linux & Open Source Solutions
http://www.sourcepole.com
Qgis-developer mailing list
Qgis-developer at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20130710/c786b017/attachment.html>
