[Qgis-developer] map rendering time much longer on windows than on ubuntu
Denis Rouzaud
denis.rouzaud at gmail.com
Wed Jul 10 23:01:29 PDT 2013
Hi all,
Finally, it was due to a bad configuration of the network card. Requests
take the same time, but QGIS is still a bit slower.
I will try to have a version without debug symbols.
Thanks for your help.
Cheers,
Denis
On 07/10/2013 10:19 AM, Jürgen E. Fischer wrote:
> Hi Denis,
> On Wed, 10. Jul 2013 at 09:52:33 +0200, Denis Rouzaud wrote:
>> Also, I'd like to try to remove the debug info.
>> Is the correct way to do this: in environment variables: add a
>> QGIS_DEBUG variable with -1 value in the user variables?
> That would still produce the output, but not show it. Not sure if the pure
> production alone also has a noticable impact.
> But the production of the output doesn't really explain, why the same requests
> are sometimes slower. Maybe looking at the output would help here ;)
> Otherwise getting rid of debugging output completely would require a Release
> build (which would not include -DQGISDEBUG).
> Jürgen
