[Qgis-developer] SEXTANTE: R output?
Victor Olaya
volayaf at gmail.com
Thu Jul 11 08:11:14 PDT 2013
I have started having a look at this...and It seems to be working on 3.0...
I am on windows and both raster and vector algorithms are working, It
installed all needed packages on first execution, and now it all works
fine.
I fixed a bug in the way the R intallation is tested, but I guess that
was not a big issue (it was only a windows problem)
The problems seems to be related to libraries being installed...but
then not available. I am not an expert on R, and the code to install
libraries autoatically was contributed by someone else. Maybe you can
guide me on this? Any idea about how to ensure that the needed
libraries are installed?
I can try to improve the error messages, so if that happens, the users
sees a message saying "The R algorithm you have executed needs a
library that is not available. Please install library XXX manually in
your R distribution"
What do you think?
2013/7/10 Filipe Dias <filipesdias at gmail.com>:
> According to the release notes R > 3.0 should be faster than previous
> versions with "big data" so I guess it would make sense to make it the
> target version. However, most R users tend to wait a while to update. Would
> it be to difficult to support both R>3.0 and R < 3 ?
> On Wed, Jul 10, 2013 at 10:43 AM, Paolo Cavallini <cavallini at faunalia.it>
> wrote:
>> -----BEGIN PGP SIGNED MESSAGE-----
>> Hash: SHA1
>> Il 10/07/2013 11:39, Victor Olaya ha scritto:
>> > Yes, Filipe reported that and I hope I can fix it soon. I didn't have
>> > much time these last days, but let's see if I can work on it later
>> > today. Sorry for that
>> thanks
>> > p.s. One question: Is R 3.0 now more common than 2.x among R users?
>> > Should we make 3.0 the target version in SEXTANTE?
>> At least on Debian, yes:
>> http://packages.debian.org/search?keywords=r-base&searchon=names
>> All the best.
>> Paolo Cavallini - Faunalia
>> www.faunalia.eu
>> Full contact details at www.faunalia.eu/pc
>> Nuovi corsi QGIS e PostGIS: http://www.faunalia.it/calendario
>> -----BEGIN PGP SIGNATURE-----
>> Version: GnuPG v1.4.12 (GNU/Linux)
>> Comment: Using GnuPG with Icedove - http://www.enigmail.net/
>> iEYEARECAAYFAlHdLNoACgkQ/NedwLUzIr4bBwCfX9MLuiOhmLcsIplQMBpLNwqo
>> PSwAnjkmGv/eLmuwKCHhLHAuzTZqGtXw
>> =cyHN
>> -----END PGP SIGNATURE-----
