[Qgis-developer] SEXTANTE: R output?
Filipe Dias
filipesdias at gmail.com
Thu Jul 11 08:32:41 PDT 2013
The problem occurs even with maptools and rgdal installed. I tried running
"create regular sampling grid" and only a generic error message was shown.
The packages are there, but Sextante apparently cant find them
On Thu, Jul 11, 2013 at 4:22 PM, Victor Olaya <volayaf at gmail.com> wrote:
> even that simple one requires rgdal, which is installed by SEXTANTE if
> not already installed. Could you send the R log file so I can see
> what's going on?
> thanks!
> 2013/7/11 Paolo Cavallini <cavallini at faunalia.it>:
> > -----BEGIN PGP SIGNED MESSAGE-----
> > Hash: SHA1
> > Il 11/07/2013 17:11, Victor Olaya ha scritto:
> >> The problems seems to be related to libraries being installed...but
> >> then not available. I am not an expert on R, and the code to install
> >> libraries autoatically was contributed by someone else. Maybe you can
> >> guide me on this? Any idea about how to ensure that the needed
> >> libraries are installed?
> >> I can try to improve the error messages, so if that happens, the users
> >> sees a message saying "The R algorithm you have executed needs a
> >> library that is not available. Please install library XXX manually in
> >> your R distribution"
> >> What do you think?
> > Hi Victor,
> > I'm not sure this is my problem: even the supersimple
> > hist(as.matrix(layer))
> > fails.
> > All the best.
> > Paolo Cavallini - Faunalia
> > www.faunalia.eu
> > Full contact details at www.faunalia.eu/pc
> > Nuovi corsi QGIS e PostGIS: http://www.faunalia.it/calendario
> > -----BEGIN PGP SIGNATURE-----
> > Version: GnuPG v1.4.12 (GNU/Linux)
> > Comment: Using GnuPG with Icedove - http://www.enigmail.net/
> > iEYEARECAAYFAlHezBMACgkQ/NedwLUzIr49pgCaA+M8FXSaRXaspZ/1Pucvx7Vt
> > ECAAoIevU8hWZKHwBPVcCZ1AsPlJEgsR
> > =TJCy
> > -----END PGP SIGNATURE-----
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20130711/86f3ad91/attachment.html>
