[Qgis-developer] SEXTANTE: R output?
Victor Olaya
volayaf at gmail.com
Thu Jul 11 08:37:59 PDT 2013
mmm, SEXTANTE doesn't have to find them...it's R that uses them.
Someone mentioned in the past a problem with packages paths...but my
knowledge of R is limited, so I don't know what I can do... :-(
2013/7/11 Filipe Dias <filipesdias at gmail.com>:
> Hi,
> The problem occurs even with maptools and rgdal installed. I tried running
> "create regular sampling grid" and only a generic error message was shown.
> The packages are there, but Sextante apparently cant find them
> On Thu, Jul 11, 2013 at 4:22 PM, Victor Olaya <volayaf at gmail.com> wrote:
>> even that simple one requires rgdal, which is installed by SEXTANTE if
>> not already installed. Could you send the R log file so I can see
>> what's going on?
>> thanks!
>> 2013/7/11 Paolo Cavallini <cavallini at faunalia.it>:
>> > -----BEGIN PGP SIGNED MESSAGE-----
>> > Hash: SHA1
>> > Il 11/07/2013 17:11, Victor Olaya ha scritto:
>> >> The problems seems to be related to libraries being installed...but
>> >> then not available. I am not an expert on R, and the code to install
>> >> libraries autoatically was contributed by someone else. Maybe you can
>> >> guide me on this? Any idea about how to ensure that the needed
>> >> libraries are installed?
>> >> I can try to improve the error messages, so if that happens, the users
>> >> sees a message saying "The R algorithm you have executed needs a
>> >> library that is not available. Please install library XXX manually in
>> >> your R distribution"
>> >> What do you think?
>> > Hi Victor,
>> > I'm not sure this is my problem: even the supersimple
>> > hist(as.matrix(layer))
>> > fails.
>> > All the best.
>> > Paolo Cavallini - Faunalia
>> > www.faunalia.eu
>> > Full contact details at www.faunalia.eu/pc
>> > Nuovi corsi QGIS e PostGIS: http://www.faunalia.it/calendario
>> > -----BEGIN PGP SIGNATURE-----
>> > Version: GnuPG v1.4.12 (GNU/Linux)
>> > Comment: Using GnuPG with Icedove - http://www.enigmail.net/
>> > iEYEARECAAYFAlHezBMACgkQ/NedwLUzIr49pgCaA+M8FXSaRXaspZ/1Pucvx7Vt
>> > ECAAoIevU8hWZKHwBPVcCZ1AsPlJEgsR
>> > =TJCy
>> > -----END PGP SIGNATURE-----
