[Qgis-developer] Toolbar and Panel defaults
Larry Shaffer larrys at dakotacarto.com
Thu Jul 11 18:32:14 PDT 2013
On Thu, Jul 11, 2013 at 5:33 PM, Pirmin Kalberer <pi_ml at sourcepole.com>wrote:
> Hi Larry, Nathan,
> Am Mittwoch, 10. Juli 2013, 17.05:56 schrieb Larry Shaffer:
> > On Wed, Jul 10, 2013 at 4:51 PM, Nathan Woodrow <madmanwoo at gmail.com>
> wrote:
> > > Having the nav toolbar on the side would be ideal if you could dock it
> on
> > > the right side of the layers panel.  I'm not a fan of having to go all
> the
> > > way over the layer panel to access the navigation tools.
> > That's a very good point. What about the Navigation toolbar on the right,
> > with the Plugin toolbar filling the empty space at right on the first row
> > of horizontal toolbars?
> > Here's my reasoning. Nav tools are quickly accessible, and when a new
> user
> > downloads/installs a plugin, there is already space to show it (assuming
> > that plugin loads a tool button into the Plugins toolbar). Then the user
> > can move toolbars to their liking.
> > Any other ideas?
> I'm not a friend of a toolbar on the right side, because it's too far away
> when the Sextante toolbox is displayed.
> I propose to put the layer toolbar on the left side. This will feel quite
> new
> for most users, but it makes sense to have it at the side of the layers
> panel
> and the browser which also has an "add layer" functionality.
> +1 for activating the plugin toolbar filling empty space.
So, going with your suggestion of having Manage Layers toolbar on left, and
Plugins toolbar filling space to right of Help toolbar, the layout would
look like this [0] (using latest icons from Denis [1]).
+1 for this as default layout.
Couple of things need some work:
* The New Spatialite Layer needs a new icon, and its icon added to the
toolbar
* When all other core plugins are turned on (that have a add or new layer
function) it looks confusing, like this [2] (after a restart). To fix, just
need to ensure the Oracle and SQL Anywhere (also needs new icon) icons go
before the W*S icons and the New GPX Layer goes before the Remove Layer
icon. This way, the icon grouping continues to make sense: Add, New, Remove.
* Help icon looks a little too dominant, or possible too far off-style.
[0] http://drive.dakotacarto.com/qgis/qgis_default_manage-layers_left.png
[1] https://github.com/qgis/Quantum-GIS/pull/700
[2]
http://drive.dakotacarto.com/qgis/qgis_default_manage-layers_left-all.png
Regards,
Larry
Pirmin
> > [0] http://drive.dakotacarto.com/qgis/qgis_default_nav-tools-right.png
> > Regards,
> > Larry
> > - Nathan
> > > On Thu, Jul 11, 2013 at 8:49 AM, Larry Shaffer
> <larrys at dakotacarto.com>wrote:
> > >> H Pirmin,
> > >> On Wed, Jul 10, 2013 at 3:29 PM, Pirmin Kalberer
> > >>> Hi Jürgen,
> > >>> Am Mittwoch, 10. Juli 2013, 08.38:38 schrieb Jürgen E. Fischer:
> > >>> > On Tue, 09. Jul 2013 at 22:55:18 +0200, Pirmin Kalberer wrote:
> > >>> > > Toolbars:
> > >>> > > -Turn off Advanced Digitizing
> > >>> > > -Move Label to second row
> > >>> > > Panels:
> > >>> > > -Turn on Layer order and Browser in a tabbed view with Layers
> > >>> > > Print composer:
> > >>> > > -Place all toolbars in one row
> > >>> > In case anyone missed it:  scripts/mkuidefaults.py produces
> > >>> > src/app/ui_defaults.h from the current settings.
> > >>> Didn't know that. Updated the script to support composer UI defaults.
> > >> Couple of other ideas comments, too:
> > >> * Currently there are no side toolbars by default. Many apps utilize
> the
> > >> left side toolbar for critical tools. To me, such tools in a GIS app
> are
> > >> the canvas navigation tools. So whenever I to an initial setup of
> QGIS, I
> > >> always put the Map Navigation toolbar on the left.
> > >> * Similarly, I always place the Plugins toolbar on the right side.
> There
> > >> is currently a bug that sets that toolbar to not be shown on a default
> > >> install (that should be fixed).
> > >> I would like to hear feedback on those two suggestions for default
> side
> > >> toolbars. Following your suggestions (and mine), the default window
> would
> > >> look similar to this (on Mac) [0].
> > >> +1 for removing Advanced Digitizing toolbar as a default, as all of
> the
> > >> functions are available in the Edit menu already. If needed, the user
> can
> > >> show that toolbar.
> > >> Another major layout issue is what the layout looks like after
> turning on
> > >> all core plugins [1]. Then, what it looks like when all those plugin
> > >> toolbars are shown [2]. This needs some work.
> > >> [0] http://drive.dakotacarto.com/qgis/qgis_default.png
> > >> [1]
> http://drive.dakotacarto.com/qgis/qgis_default_core-plugins_no-extra-tool
> > >> bars.png [2]
> http://drive.dakotacarto.com/qgis/qgis_default_core-plugins_with-toolbars
> > >> .png
> > >> Regards,
> > >> Larry
> > >>> > So updating it should be easy, once it's decides what should be the
> > >>> default.
> > >>> > Not sure if the data contains pixel coordinates and if the screen
> > >>> resolution
> > >>> > might therefore be an issue...
> > >>> Let's try: https://github.com/qgis/Quantum-GIS/pull/710
> > >>> Pirmin
> > >>> Pirmin Kalberer
> > >>> Sourcepole  -  Linux & Open Source Solutions
> > >>> http://www.sourcepole.com
> > >>> _______________________________________________
> > >>> Qgis-developer mailing list
> > >>> Qgis-developer at lists.osgeo.org
> > >>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Pirmin Kalberer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20130711/69ec00db/attachment.html>
