[Qgis-developer] Splash screen for 2.0
Tim Sutton lists at linfiniti.com
Mon Jul 15 04:54:13 PDT 2013
Hi
On Mon, Jul 15, 2013 at 1:44 PM, Andreas Neumann <a.neumann at carto.net>wrote:
> and here is v3:
> http://www.carto.net/neumann/temp/qgis_splashscreen_v3.png
> I added the copyright. If we decide for that version I will have to ask
> for permission and probably have to set the copyright somewhere.
OK the copyright will be obscured by white / light stripe for progress
messages I mentioned in my previous email. Can you move it somewhere else?
And also  can you indicate that the copyright  applies to the image only
(e.g. Background image copyright Swisstopo) - otherwise it looks like the
whole of QGIS is copyright to them.
Regards
Tim
> Andreas
> Am 15.07.2013 13:38, schrieb Andreas Neumann:
> > Hi,
> > I agree - the text could be more legible.
> > I would propose to lighten the background map a bit to make the text
> > more legible. I also changed the stroke-width of the version text a bit
> > to make it more legible.
> > See
> > http://www.carto.net/neumann/temp/qgis_splashscreen_v2.png
> > compared to the old version
> > http://www.carto.net/neumann/temp/qgis_splashscreen.png
> > Andreas
> > Am 15.07.2013 12:16, schrieb Sandro Santilli:
> >> On Mon, Jul 15, 2013 at 12:09:11PM +0200, Andreas Neumann wrote:
> >>> Hi,
> >>> Here is my try for a splash-screen:
> >> There's not enough contrast between the background and
> >> the wording, making it hard to read "QGIS" and harder to
> >> read the version and name. I like the "water effect" :)
> >> --strk;
> > Qgis-developer mailing list
> > Qgis-developer at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/qgis-developer
Tim Sutton - QGIS Project Steering Committee Member (Release  Manager)
Please do not email me off-list with technical
support questions. Using the lists will gain
more exposure for your issues and the knowledge
surrounding your issue will be shared with all.
Irc: timlinux on #qgis at freenode.net
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20130715/292f1e61/attachment-0001.html>
