[Qgis-developer] Splash screen for 2.0
Andreas Neumann a.neumann at carto.net
Mon Jul 15 05:02:21 PDT 2013
Hi Tim and others,
I can add the white stripe at the bottom.
Do you want the rounded corners and white borders again?
I can also try to fill the "QGIS" text with a white transparent fill as
Nathan suggests.
Andreas
Am 15.07.2013 13:54, schrieb Tim Sutton:
> Hi
> On Mon, Jul 15, 2013 at 1:44 PM, Andreas Neumann <a.neumann at carto.net>wrote:
>> and here is v3:
>> http://www.carto.net/neumann/temp/qgis_splashscreen_v3.png
>> I added the copyright. If we decide for that version I will have to ask
>> for permission and probably have to set the copyright somewhere.
> OK the copyright will be obscured by white / light stripe for progress
> messages I mentioned in my previous email. Can you move it somewhere else?
> And also  can you indicate that the copyright  applies to the image only
> (e.g. Background image copyright Swisstopo) - otherwise it looks like the
> whole of QGIS is copyright to them.
> Regards
> Tim
>> Andreas
>> Am 15.07.2013 13:38, schrieb Andreas Neumann:
>>> Hi,
>>> I agree - the text could be more legible.
>>> I would propose to lighten the background map a bit to make the text
>>> more legible. I also changed the stroke-width of the version text a bit
>>> to make it more legible.
>>> See
>>> http://www.carto.net/neumann/temp/qgis_splashscreen_v2.png
>>> compared to the old version
>>> http://www.carto.net/neumann/temp/qgis_splashscreen.png
>>> Andreas
>>> Am 15.07.2013 12:16, schrieb Sandro Santilli:
>>>> On Mon, Jul 15, 2013 at 12:09:11PM +0200, Andreas Neumann wrote:
>>>>> Hi,
>>>>> Here is my try for a splash-screen:
>>>> There's not enough contrast between the background and
>>>> the wording, making it hard to read "QGIS" and harder to
>>>> read the version and name. I like the "water effect" :)
>>>> --strk;
>>> Qgis-developer mailing list
>>> Qgis-developer at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
