[Qgis-developer] Splash screen for 2.0
Tim Sutton
lists at linfiniti.com
Mon Jul 15 05:04:30 PDT 2013
Hi
On Mon, Jul 15, 2013 at 2:02 PM, Andreas Neumann <a.neumann at carto.net>wrote:
> Hi Tim and others,
> I can add the white stripe at the bottom.
Great thanks.
> Do you want the rounded corners and white borders again?
I like them others don't. So I'm happy either way. If you do go non-rounded
the mask file needs updating too.
> I can also try to fill the "QGIS" text with a white transparent fill as
> Nathan suggests.
Ok great.
Thanks
Tim
> Andreas
> Am 15.07.2013 13:54, schrieb Tim Sutton:
> > Hi
> > On Mon, Jul 15, 2013 at 1:44 PM, Andreas Neumann <a.neumann at carto.net
> >wrote:
> >> and here is v3:
> >> http://www.carto.net/neumann/temp/qgis_splashscreen_v3.png
> >> I added the copyright. If we decide for that version I will have to ask
> >> for permission and probably have to set the copyright somewhere.
> > OK the copyright will be obscured by white / light stripe for progress
> > messages I mentioned in my previous email. Can you move it somewhere
> else?
> > And also can you indicate that the copyright applies to the image only
> > (e.g. Background image copyright Swisstopo) - otherwise it looks like the
> > whole of QGIS is copyright to them.
> > Regards
> > Tim
> >> Andreas
> >> Am 15.07.2013 13:38, schrieb Andreas Neumann:
> >>> Hi,
> >>> I agree - the text could be more legible.
> >>> I would propose to lighten the background map a bit to make the text
> >>> more legible. I also changed the stroke-width of the version text a bit
> >>> to make it more legible.
> >>> See
> >>> http://www.carto.net/neumann/temp/qgis_splashscreen_v2.png
> >>> compared to the old version
> >>> http://www.carto.net/neumann/temp/qgis_splashscreen.png
> >>> Andreas
> >>> Am 15.07.2013 12:16, schrieb Sandro Santilli:
> >>>> On Mon, Jul 15, 2013 at 12:09:11PM +0200, Andreas Neumann wrote:
> >>>>> Hi,
> >>>>> Here is my try for a splash-screen:
> >>>> There's not enough contrast between the background and
> >>>> the wording, making it hard to read "QGIS" and harder to
> >>>> read the version and name. I like the "water effect" :)
> >>>> --strk;
> >>> _______________________________________________
> >>> Qgis-developer mailing list
> >>> Qgis-developer at lists.osgeo.org
> >>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
Tim Sutton - QGIS Project Steering Committee Member (Release Manager)
Please do not email me off-list with technical
support questions. Using the lists will gain
more exposure for your issues and the knowledge
surrounding your issue will be shared with all.
Irc: timlinux on #qgis at freenode.net
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20130715/e5089fd6/attachment.html>
