[Qgis-developer] New API: get attribute values from a PostGIS layer
Stéphane Henriod s at henriod.info
Wed Jul 17 12:13:05 PDT 2013
Dear all
I am trying to get into the new 2.0 API and am still facing issues for very
basic stuff: getting the values of the attributes out of a PostGIS layer.
Basically, it works (with the almost same code) in the Qgis python console,
but I don't manage to get it to work in a stand-alone script.
What I have so far is a PostGIS layer, that I load with:
*uri = QgsDataSourceURI()
> uri.setConnection('localhost', '5432', 'db_name', 'user_name', 'password')
> uri.setDataSource('my_schema', 'my_table', 'the_geom')
> my_layer = QgsVectorLayer(uri.uri(),'myhospitals','postgres')
A quick test shows me that the layer has been successfully loaded:
*if not my_layer.isValid():
>     print "Layer failed to load!"
> else:
>     print "Layer loaded successfully"
I would assume that
*for elem in my_layer.getFeatures():*
> *    print elem.attributes()*
should return the attributes in a usable format but, instead, I get:
> *[<PyQt4.QtCore.QVariant object at 0xad37aca4>, <PyQt4.QtCore.QVariant
> object at 0xad37acdc>, None, <PyQt4.QtCore.QVariant object at 0xad37ad14>]
> object at 0xad37acdc>, <PyQt4.QtCore.QVariant object at 0xad37ad14>,
> <PyQt4.QtCore.QVariant object at 0xad37ad4c>]*
Does anyone have an idea where the problem could lie?
For those who speak French, the question is posted here as well:
http://www.forumsig.org/showthread.php/37178-Nouvelle-API-r%C3%A9cup%C3%A9rer-les-valeurs-attributaires
I am using Qgis 1.9.0 with Python 2.7 on Ubuntu 13.04
Thanks in advance for ideas and comments...
Cheers
Stéphane
"Le mot progrès n'aura aucun sens tant qu'il y aura des enfants malheureux"
-- Albert Einstein
"A journey does not need reasons. Before long, it proves to be reason
enough in itself. One thinks that one is going to make a journey, yet soon
it is the journey that makes or unmakes you." -- Nicolas Bouvier
Photos de voyages, photos de montagne: http://www.henriod.info
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20130717/88e2ea47/attachment.html>
