[Qgis-developer] New API: get attribute values from a PostGIS layer
Vincent Mora
vincent.mora at oslandia.com
Wed Jul 17 14:28:27 PDT 2013
Hi Stephan,
We modified the postgis-workshop tutorial for qgis plugin development to
use the new python api of qgis 1.9, there are examples of feature access
in there:
https://github.com/Oslandia/postgis-workshop
Cheers,
Vincent.
On 17/07/2013 21:13, Stéphane Henriod wrote:
> Dear all
> I am trying to get into the new 2.0 API and am still facing issues for
> very basic stuff: getting the values of the attributes out of a
> PostGIS layer.
> Basically, it works (with the almost same code) in the Qgis python
> console, but I don't manage to get it to work in a stand-alone script.
> What I have so far is a PostGIS layer, that I load with:
> /uri = QgsDataSourceURI()
> uri.setConnection('localhost', '5432', 'db_name', 'user_name',
> 'password')
> uri.setDataSource('my_schema', 'my_table', 'the_geom')
> my_layer = QgsVectorLayer(uri.uri(),'myhospitals','postgres')
> A quick test shows me that the layer has been successfully loaded:
> /if not my_layer.isValid():
> print "Layer failed to load!"
> else:
> print "Layer loaded successfully"
> I would assume that
> /for elem in my_layer.getFeatures():/
> / print elem.attributes()/
> should return the attributes in a usable format but, instead, I get:
> /[<PyQt4.QtCore.QVariant object at 0xad37aca4>,
> <PyQt4.QtCore.QVariant object at 0xad37acdc>, None,
> <PyQt4.QtCore.QVariant object at 0xad37ad14>]/
> <PyQt4.QtCore.QVariant object at 0xad37ad14>,
> <PyQt4.QtCore.QVariant object at 0xad37ad4c>]/
> Does anyone have an idea where the problem could lie?
> For those who speak French, the question is posted here as well:
> http://www.forumsig.org/showthread.php/37178-Nouvelle-API-r%C3%A9cup%C3%A9rer-les-valeurs-attributaires
> I am using Qgis 1.9.0 with Python 2.7 on Ubuntu 13.04
> Thanks in advance for ideas and comments...
> Cheers
> Stéphane
> "Le mot progrès n'aura aucun sens tant qu'il y aura des enfants
> malheureux" -- Albert Einstein
> "A journey does not need reasons. Before long, it proves to be reason
> enough in itself. One thinks that one is going to make a journey, yet
> soon it is the journey that makes or unmakes you." -- Nicolas Bouvier
> Photos de voyages, photos de montagne: http://www.henriod.info
> <http://www.henriod.info/>
> Qgis-developer mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20130717/af03e72c/attachment.html>
