[Qgis-developer] Splash screen for 2.0
Tim Sutton
lists at linfiniti.com
Tue Jul 23 00:35:03 PDT 2013
Hi
My 2c below:
On Mon, Jul 22, 2013 at 6:29 PM, Larry Shaffer <larrys at dakotacarto.com>wrote:
> Hi,
> On Tue, Jul 16, 2013 at 6:57 PM, Nathan Woodrow <madmanwoo at gmail.com>wrote:
>> Here is a version with the green but also the full logo:
>> https://www.dropbox.com/s/u6bj807cesttnwl/qgis_green3.png
> +1, I think the layout and color selection are good. The layout doesn't
> include that dark grey border, does it? If so, please consider removing it.
I think the Q logo should be smaller, say 1/3 the splash hight and nestled
into the top left corner (with some white space around it) and with no
transparency.
> Also, the font used for 'QGIS' is rather weak and, to be frank, a bit
> goofy-looking (especially the Q). I have a huge assortment of professional
> fonts which I can work with to find something better.
Agreed - though can you please use a font that is free or at least easily
available and provide the final splash as a gimp xcf so that we can easily
re-use it in future releases.
> Nathan, do you have a working design file I can use? Or at least a
> background PNG without the lettering?
> There appears to be no leading between the lines 'QGIS 2.0' and 'Dufour,'
> nor spacing between 'QGIS' and '2.0.' Was this intended? I do kind of like
> the effect, however. Usually when this is done in design, at minimum, the
> coloring of the two words/lines is different, even if just a difference in
> tone of the same color.
I agree with this, it needs a little more white space between the words.
Also a note that we usually store the master splash in much higher
resolution so that it can be used in posters / printed products etc. A
downsampled one is then used for the final splash. Ideally in future
releases we would just swap out the background image and edit the text
containing the version and name.
Regards
Tim
Regards,
> Larry
>> - Nathan
>> On Wed, Jul 17, 2013 at 1:18 AM, Marco Bernasocchi <
>> marco at bernawebdesign.ch> wrote:
>>> On 07/16/2013 03:02 PM, Matthias Kuhn wrote:
>>> Currently, all splash screen drafts I have seen are heavily based on
>>>> swisstopo maps. While I personally like these very well-done maps, I
>>>> don't see the connection between these and QGIS. For me, looking at the
>>>> splashes feels like looking at a swisstopo advertisement.
>>>> I would prefer a version, where we show off the new features of QGIS
>>>> and/or having a historical map instead of just showing a standard
>>>> product of the official Swiss map-makers.
>>> I agree with Matthias, and I'll suggest again (as Andreas did before) to
>>> try the dufour map: http://s.geo.admin.ch/**09751c84f<http://s.geo.admin.ch/09751c84f>or maybe the sigfriedkarte
>>> ciao
>>> Marco Bernasocchi
>>> http://opengis.ch
>>> ______________________________**_________________
>>> Qgis-developer mailing list
>>> Qgis-developer at lists.osgeo.org
>>> http://lists.osgeo.org/**mailman/listinfo/qgis-**developer<http://lists.osgeo.org/mailman/listinfo/qgis-developer>
Tim Sutton - QGIS Project Steering Committee Member (Release Manager)
Please do not email me off-list with technical
support questions. Using the lists will gain
more exposure for your issues and the knowledge
surrounding your issue will be shared with all.
Irc: timlinux on #qgis at freenode.net
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20130723/89334ddd/attachment.html>
