[Qgis-developer] Bugs in QGIS Master
Oscar van Vliet ovvldc at gmail.com
Wed Jul 24 23:28:22 PDT 2013
Dear QGIS developers,
Thanks for all the hard work, I have been using the almost 2.0 builds with
some satisfaction. Unfortunately, all is not well. I am using yesterday's
Master build, and there seems to be a few bugs still.
First of all, the dialog window for Raster|Analysis|DEM is too tall for my
Macbook, which only has 800 pixels vertically. You might consider
rearranging it a little. I can still use it by starting the analysis by
hitting Enter, but I cannot actually see the bottom row of buttons or the
resize widget.
Second, I have some errors in the Raster|Conversion|Rasterise dialog that
make it unusable for me.
I am trying to rasterise a vector layer that I saved as a selection from a
layer that I had previously vectorised.
I understand this dialog is just a front for GDAL tools, but the bridge
seems to be broken: I get the following python error when I try to select a
filename for the rasterised output layer:
  File
"/Applications/GIS/QGIS_2.0-dev_SnoLeo.app/Contents/MacOS/../Resources/python/plugins/GdalTools/tools/doRasterize.py",
line 102, in fillOutputFileEdit
    outputFile = fileDialogFunc(self, self.tr( "Select the raster file to
save the results to" ), Utils.FileFilter.allRastersFilter(), lastUsedFilter)
  File
"/Applications/GIS/QGIS_2.0-dev_SnoLeo.app/Contents/MacOS/../Resources/python/plugins/GdalTools/tools/GdalTools_utils.py",
line 413, in getSaveFileName
    return self.getDialog(parent, caption, QFileDialog.AcceptSave,
QFileDialog.AnyFile, filter, selectedFilter, useEncoding)
  File
line 362, in getDialog
    dialog.selectNameFilter(selectedFilter)
TypeError: QFileDialog.selectNameFilter(QString): argument 1 has unexpected
type 'QPyNullVariant'
Python versie:
2.6.1 (r261:67515, Jun 24 2010, 21:47:49)
[GCC 4.2.1 (Apple Inc. build 5646)]
QGIS versie:
1.9.0-Master Master, 5c2e3f3
Python pad:
['/Applications/GIS/QGIS_2.0-dev_SnoLeo.app/Contents/MacOS/../Resources/python',
'/Users/XX/.qgis2/python', '/Users/XX/.qgis2/python/plugins',
'/Applications/GIS/QGIS_2.0-dev_SnoLeo.app/Contents/MacOS/../Resources/python/plugins',
'/Library/Frameworks/SQLite3.framework/Versions/B/Python/2.6',
'/Library/Python/2.6/site-packages/numpy-override',
'/Library/Frameworks/GDAL.framework/Versions/1.10/Python/2.6/site-packages',
'/Library/Frameworks/cairo.framework/Versions/1/Python/2.6',
'/System/Library/Frameworks/Python.framework/Versions/2.6/lib/python26.zip',
'/System/Library/Frameworks/Python.framework/Versions/2.6/lib/python2.6',
'/System/Library/Frameworks/Python.framework/Versions/2.6/lib/python2.6/plat-darwin',
'/System/Library/Frameworks/Python.framework/Versions/2.6/lib/python2.6/plat-mac',
'/System/Library/Frameworks/Python.framework/Versions/2.6/lib/python2.6/plat-mac/lib-scriptpackages',
'/System/Library/Frameworks/Python.framework/Versions/2.6/Extras/lib/python',
'/System/Library/Frameworks/Python.framework/Versions/2.6/lib/python2.6/lib-tk',
'/System/Library/Frameworks/Python.framework/Versions/2.6/lib/python2.6/lib-old',
'/System/Library/Frameworks/Python.framework/Versions/2.6/lib/python2.6/lib-dynload',
'/Library/Python/2.6/site-packages',
'/Library/Python/2.6/site-packages/PIL',
'/System/Library/Frameworks/Python.framework/Versions/2.6/Extras/lib/python/PyObjC',
'/System/Library/Frameworks/Python.framework/Versions/2.6/Extras/lib/python/wx-2.8-mac-unicode',
'/Applications/GIS/QGIS_2.0-dev_SnoLeo.app/Contents/Resources/python/plugins/fTools/tools',
'/Users/XX/YY/ZZ']
Then if I try to run it with the existing size, I get another python error.
If I choose the option with pixel size, the action just seems to hang
without resolving or any error message.
I hope this makes sense. I have installed all of the required packages from
kyngchaos, AFAIK. Feel free to contact me for additional data.
Best wishes,
 Oscar
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20130725/378e284a/attachment.html>
