[Qgis-developer] Bugs in QGIS Master
Gino Pirelli
luipir at gmail.com
Thu Jul 25 04:19:37 PDT 2013
Hi
I don't know what's your windows system... generally on gnome or kde
using Alt+7 and cliking on the window allow you to pan the gui along
the window.
this doesn't append to me in gnome3 or unity... but probabilly i've to
find the correct key combination.
I don't know using osx window manager
another workaround is to change application font sizes of your desktop
configuration.
ciao ginetto (luigi.pirelli at faunalia.it)
On 25 July 2013 08:28, Oscar van Vliet <ovvldc at gmail.com> wrote:
> Dear QGIS developers,
> Thanks for all the hard work, I have been using the almost 2.0 builds with
> some satisfaction. Unfortunately, all is not well. I am using yesterday's
> Master build, and there seems to be a few bugs still.
> First of all, the dialog window for Raster|Analysis|DEM is too tall for my
> Macbook, which only has 800 pixels vertically. You might consider
> rearranging it a little. I can still use it by starting the analysis by
> hitting Enter, but I cannot actually see the bottom row of buttons or the
> resize widget.
> Second, I have some errors in the Raster|Conversion|Rasterise dialog that
> make it unusable for me.
> I am trying to rasterise a vector layer that I saved as a selection from a
> layer that I had previously vectorised.
> I understand this dialog is just a front for GDAL tools, but the bridge
> seems to be broken: I get the following python error when I try to select a
> filename for the rasterised output layer:
> Traceback (most recent call last):
> File
> "/Applications/GIS/QGIS_2.0-dev_SnoLeo.app/Contents/MacOS/../Resources/python/plugins/GdalTools/tools/doRasterize.py",
> line 102, in fillOutputFileEdit
> outputFile = fileDialogFunc(self, self.tr( "Select the raster file to
> save the results to" ), Utils.FileFilter.allRastersFilter(), lastUsedFilter)
> File
> "/Applications/GIS/QGIS_2.0-dev_SnoLeo.app/Contents/MacOS/../Resources/python/plugins/GdalTools/tools/GdalTools_utils.py",
> line 413, in getSaveFileName
> return self.getDialog(parent, caption, QFileDialog.AcceptSave,
> QFileDialog.AnyFile, filter, selectedFilter, useEncoding)
> File
> line 362, in getDialog
> dialog.selectNameFilter(selectedFilter)
> TypeError: QFileDialog.selectNameFilter(QString): argument 1 has unexpected
> type 'QPyNullVariant'
> Python versie:
> 2.6.1 (r261:67515, Jun 24 2010, 21:47:49)
> [GCC 4.2.1 (Apple Inc. build 5646)]
> QGIS versie:
> 1.9.0-Master Master, 5c2e3f3
> Python pad:
> ['/Applications/GIS/QGIS_2.0-dev_SnoLeo.app/Contents/MacOS/../Resources/python',
> '/Users/XX/.qgis2/python', '/Users/XX/.qgis2/python/plugins',
> '/Applications/GIS/QGIS_2.0-dev_SnoLeo.app/Contents/MacOS/../Resources/python/plugins',
> '/Library/Frameworks/SQLite3.framework/Versions/B/Python/2.6',
> '/Library/Python/2.6/site-packages/numpy-override',
> '/Library/Frameworks/GDAL.framework/Versions/1.10/Python/2.6/site-packages',
> '/Library/Frameworks/cairo.framework/Versions/1/Python/2.6',
> '/System/Library/Frameworks/Python.framework/Versions/2.6/lib/python26.zip',
> '/System/Library/Frameworks/Python.framework/Versions/2.6/lib/python2.6',
> '/System/Library/Frameworks/Python.framework/Versions/2.6/lib/python2.6/plat-darwin',
> '/System/Library/Frameworks/Python.framework/Versions/2.6/lib/python2.6/plat-mac',
> '/System/Library/Frameworks/Python.framework/Versions/2.6/lib/python2.6/plat-mac/lib-scriptpackages',
> '/System/Library/Frameworks/Python.framework/Versions/2.6/Extras/lib/python',
> '/System/Library/Frameworks/Python.framework/Versions/2.6/lib/python2.6/lib-tk',
> '/System/Library/Frameworks/Python.framework/Versions/2.6/lib/python2.6/lib-old',
> '/System/Library/Frameworks/Python.framework/Versions/2.6/lib/python2.6/lib-dynload',
> '/Library/Python/2.6/site-packages',
> '/Library/Python/2.6/site-packages/PIL',
> '/System/Library/Frameworks/Python.framework/Versions/2.6/Extras/lib/python/PyObjC',
> '/System/Library/Frameworks/Python.framework/Versions/2.6/Extras/lib/python/wx-2.8-mac-unicode',
> '/Applications/GIS/QGIS_2.0-dev_SnoLeo.app/Contents/Resources/python/plugins/fTools/tools',
> '/Users/XX/YY/ZZ']
> Then if I try to run it with the existing size, I get another python error.
> If I choose the option with pixel size, the action just seems to hang
> without resolving or any error message.
> I hope this makes sense. I have installed all of the required packages from
> kyngchaos, AFAIK. Feel free to contact me for additional data.
> Best wishes,
> Oscar
> Qgis-developer mailing list
