[Qgis-developer] Bugs in QGIS Master
Etienne Tourigny
etourigny.dev at gmail.com
Thu Jul 25 05:10:37 PDT 2013
On Thu, Jul 25, 2013 at 3:28 AM, Oscar van Vliet <ovvldc at gmail.com> wrote:
> Dear QGIS developers,
> Thanks for all the hard work, I have been using the almost 2.0 builds with
> some satisfaction. Unfortunately, all is not well. I am using yesterday's
> Master build, and there seems to be a few bugs still.
> First of all, the dialog window for Raster|Analysis|DEM is too tall for my
> Macbook, which only has 800 pixels vertically. You might consider
> rearranging it a little. I can still use it by starting the analysis by
> hitting Enter, but I cannot actually see the bottom row of buttons or the
> resize widget.
Admittedly the vertical size of that dialog is a bit large.
If you close the "Creation Options" section, can you resize the window and
see the bottom buttons?
> Second, I have some errors in the Raster|Conversion|Rasterise dialog that
> make it unusable for me.
> I am trying to rasterise a vector layer that I saved as a selection from a
> layer that I had previously vectorised.
> I understand this dialog is just a front for GDAL tools, but the bridge
> seems to be broken: I get the following python error when I try to select a
> filename for the rasterised output layer:
> Traceback (most recent call last):
> File
> "/Applications/GIS/QGIS_2.0-dev_SnoLeo.app/Contents/MacOS/../Resources/python/plugins/GdalTools/tools/doRasterize.py",
> line 102, in fillOutputFileEdit
> outputFile = fileDialogFunc(self, self.tr( "Select the raster file to
> save the results to" ), Utils.FileFilter.allRastersFilter(), lastUsedFilter)
> File
> "/Applications/GIS/QGIS_2.0-dev_SnoLeo.app/Contents/MacOS/../Resources/python/plugins/GdalTools/tools/GdalTools_utils.py",
> line 413, in getSaveFileName
> return self.getDialog(parent, caption, QFileDialog.AcceptSave,
> QFileDialog.AnyFile, filter, selectedFilter, useEncoding)
> File
> line 362, in getDialog
> dialog.selectNameFilter(selectedFilter)
> TypeError: QFileDialog.selectNameFilter(QString): argument 1 has
> unexpected type 'QPyNullVariant'
> Python versie:
> 2.6.1 (r261:67515, Jun 24 2010, 21:47:49)
> [GCC 4.2.1 (Apple Inc. build 5646)]
> QGIS versie:
> 1.9.0-Master Master, 5c2e3f3
> Python pad:
> ['/Applications/GIS/QGIS_2.0-dev_SnoLeo.app/Contents/MacOS/../Resources/python',
> '/Users/XX/.qgis2/python', '/Users/XX/.qgis2/python/plugins',
> '/Applications/GIS/QGIS_2.0-dev_SnoLeo.app/Contents/MacOS/../Resources/python/plugins',
> '/Library/Frameworks/SQLite3.framework/Versions/B/Python/2.6',
> '/Library/Python/2.6/site-packages/numpy-override',
> '/Library/Frameworks/GDAL.framework/Versions/1.10/Python/2.6/site-packages',
> '/Library/Frameworks/cairo.framework/Versions/1/Python/2.6',
> '/System/Library/Frameworks/Python.framework/Versions/2.6/lib/python26.zip',
> '/System/Library/Frameworks/Python.framework/Versions/2.6/lib/python2.6',
> '/System/Library/Frameworks/Python.framework/Versions/2.6/lib/python2.6/plat-darwin',
> '/System/Library/Frameworks/Python.framework/Versions/2.6/lib/python2.6/plat-mac',
> '/System/Library/Frameworks/Python.framework/Versions/2.6/lib/python2.6/plat-mac/lib-scriptpackages',
> '/System/Library/Frameworks/Python.framework/Versions/2.6/Extras/lib/python',
> '/System/Library/Frameworks/Python.framework/Versions/2.6/lib/python2.6/lib-tk',
> '/System/Library/Frameworks/Python.framework/Versions/2.6/lib/python2.6/lib-old',
> '/System/Library/Frameworks/Python.framework/Versions/2.6/lib/python2.6/lib-dynload',
> '/Library/Python/2.6/site-packages',
> '/Library/Python/2.6/site-packages/PIL',
> '/System/Library/Frameworks/Python.framework/Versions/2.6/Extras/lib/python/PyObjC',
> '/System/Library/Frameworks/Python.framework/Versions/2.6/Extras/lib/python/wx-2.8-mac-unicode',
> '/Applications/GIS/QGIS_2.0-dev_SnoLeo.app/Contents/Resources/python/plugins/fTools/tools',
> '/Users/XX/YY/ZZ']
> Then if I try to run it with the existing size, I get another python
> error. If I choose the option with pixel size, the action just seems to
> hang without resolving or any error message.
I cannot reproduce these 2 problems in linux, perhaps only a Mac bug?
Consider filing a bug report here:
http://hub.qgis.org/projects/quantum-gis/issues
> I hope this makes sense. I have installed all of the required packages
> from kyngchaos, AFAIK. Feel free to contact me for additional data.
> Best wishes,
> Oscar
> Qgis-developer mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20130725/6ee780b2/attachment.html>
