[Qgis-developer] Bugs in QGIS Master
Oscar van Vliet
ovvldc at gmail.com
Thu Jul 25 05:57:32 PDT 2013
Dear Etienne,
Thanks for the suggestion. If I close the creation options in the DEM, I am
still a bit short: I see the gdaldem ..... window, but the OK and Close
buttons still end up below the bottom of my screen.
I am using Mac OS X 10.6.8 on a 13" Macbook with a resolution of 1280*800
(which, I admit, is a bit small for this sort of thing).
As for the python error, I don't know if it is Mac-specific. Maybe someone
else can confirm before I file a bug? I managed to run gdal_rasterize from
the command line and it worked fine, so the problem is definitely between
QGIS and my Mac.
Best wishes,
Oscar
2013/7/25 Etienne Tourigny <etourigny.dev at gmail.com>
> On Thu, Jul 25, 2013 at 3:28 AM, Oscar van Vliet <ovvldc at gmail.com> wrote:
>> Dear QGIS developers,
>> Thanks for all the hard work, I have been using the almost 2.0 builds
>> with some satisfaction. Unfortunately, all is not well. I am using
>> yesterday's Master build, and there seems to be a few bugs still.
>> First of all, the dialog window for Raster|Analysis|DEM is too tall for
>> my Macbook, which only has 800 pixels vertically. You might consider
>> rearranging it a little. I can still use it by starting the analysis by
>> hitting Enter, but I cannot actually see the bottom row of buttons or the
>> resize widget.
> Admittedly the vertical size of that dialog is a bit large.
> If you close the "Creation Options" section, can you resize the window and
> see the bottom buttons?
>> Second, I have some errors in the Raster|Conversion|Rasterise dialog that
>> make it unusable for me.
>> I am trying to rasterise a vector layer that I saved as a selection from
>> a layer that I had previously vectorised.
>> I understand this dialog is just a front for GDAL tools, but the bridge
>> seems to be broken: I get the following python error when I try to select a
>> filename for the rasterised output layer:
>> Traceback (most recent call last):
>> File
>> "/Applications/GIS/QGIS_2.0-dev_SnoLeo.app/Contents/MacOS/../Resources/python/plugins/GdalTools/tools/doRasterize.py",
>> line 102, in fillOutputFileEdit
>> outputFile = fileDialogFunc(self, self.tr( "Select the raster file
>> to save the results to" ), Utils.FileFilter.allRastersFilter(),
>> lastUsedFilter)
>> File
>> "/Applications/GIS/QGIS_2.0-dev_SnoLeo.app/Contents/MacOS/../Resources/python/plugins/GdalTools/tools/GdalTools_utils.py",
>> line 413, in getSaveFileName
>> return self.getDialog(parent, caption, QFileDialog.AcceptSave,
>> QFileDialog.AnyFile, filter, selectedFilter, useEncoding)
>> File
>> line 362, in getDialog
>> dialog.selectNameFilter(selectedFilter)
>> TypeError: QFileDialog.selectNameFilter(QString): argument 1 has
>> unexpected type 'QPyNullVariant'
>> Python versie:
>> 2.6.1 (r261:67515, Jun 24 2010, 21:47:49)
>> [GCC 4.2.1 (Apple Inc. build 5646)]
>> QGIS versie:
>> 1.9.0-Master Master, 5c2e3f3
>> Python pad:
>> ['/Applications/GIS/QGIS_2.0-dev_SnoLeo.app/Contents/MacOS/../Resources/python',
>> '/Users/XX/.qgis2/python', '/Users/XX/.qgis2/python/plugins',
>> '/Applications/GIS/QGIS_2.0-dev_SnoLeo.app/Contents/MacOS/../Resources/python/plugins',
>> '/Library/Frameworks/SQLite3.framework/Versions/B/Python/2.6',
>> '/Library/Python/2.6/site-packages/numpy-override',
>> '/Library/Frameworks/GDAL.framework/Versions/1.10/Python/2.6/site-packages',
>> '/Library/Frameworks/cairo.framework/Versions/1/Python/2.6',
>> '/System/Library/Frameworks/Python.framework/Versions/2.6/lib/python26.zip',
>> '/System/Library/Frameworks/Python.framework/Versions/2.6/lib/python2.6',
>> '/System/Library/Frameworks/Python.framework/Versions/2.6/lib/python2.6/plat-darwin',
>> '/System/Library/Frameworks/Python.framework/Versions/2.6/lib/python2.6/plat-mac',
>> '/System/Library/Frameworks/Python.framework/Versions/2.6/lib/python2.6/plat-mac/lib-scriptpackages',
>> '/System/Library/Frameworks/Python.framework/Versions/2.6/Extras/lib/python',
>> '/System/Library/Frameworks/Python.framework/Versions/2.6/lib/python2.6/lib-tk',
>> '/System/Library/Frameworks/Python.framework/Versions/2.6/lib/python2.6/lib-old',
>> '/System/Library/Frameworks/Python.framework/Versions/2.6/lib/python2.6/lib-dynload',
>> '/Library/Python/2.6/site-packages',
>> '/Library/Python/2.6/site-packages/PIL',
>> '/System/Library/Frameworks/Python.framework/Versions/2.6/Extras/lib/python/PyObjC',
>> '/System/Library/Frameworks/Python.framework/Versions/2.6/Extras/lib/python/wx-2.8-mac-unicode',
>> '/Applications/GIS/QGIS_2.0-dev_SnoLeo.app/Contents/Resources/python/plugins/fTools/tools',
>> '/Users/XX/YY/ZZ']
>> Then if I try to run it with the existing size, I get another python
>> error. If I choose the option with pixel size, the action just seems to
>> hang without resolving or any error message.
> I cannot reproduce these 2 problems in linux, perhaps only a Mac bug?
> Consider filing a bug report here:
> http://hub.qgis.org/projects/quantum-gis/issues
>> I hope this makes sense. I have installed all of the required packages
>> from kyngchaos, AFAIK. Feel free to contact me for additional data.
>> Best wishes,
>> Oscar
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20130725/fbecb7e3/attachment.html>
