[Qgis-developer] using hub.qgis.org git repository
Alex Mandel tech_dev at wildintellect.com
Sun Jun 2 22:07:21 PDT 2013
A password will never work, so don't bother trying that. Based on the
information you've provided we will go into the server config and check
if the permissions were properly added from Redmine to gitosis.
Thanks,
Alex
On 06/02/2013 11:08 AM, Ricardo Filipe Soares Garcia da wrote:
> Hi
> I still cannot configure a repository for this project on hub.qgis.org
> When running git remote -v I get:
> ricardo at portatil:~/.qgis2/python/plugins/coneforinputs$ git remote -v
> origin    gitosis at qgis.org:coneforinputs.git (fetch)
> origin    gitosis at qgis.org:coneforinputs.git (push)
> I think this is the expected result.
> I've added myself as a developer on the project's settings. And configured
> git to be the SCM.
> When accessing the 'Repository' tab on redmine I am shown a page that says:
> Repository does not exist. Create one using the instructions below.
> Following the instructions, I've added my SSH public key again (and again)
> to my redmine profile. I've tried various combinations appending my e-mail
> address to it and not. The result is always the same. git asks me for a
> passowrd when I try to git push to the remote and then fails with
> permission denied.
> What could be the problem?
> On Thu, May 30, 2013 at 11:50 PM, Alex Mandel <tech_dev at wildintellect.com>wrote:
>> On 05/30/2013 03:42 PM, Ricardo Filipe Soares Garcia da wrote:
>>> Hi list
>>> I created a new plugin in hub.qgis.org and I'd like to use a git
>>> repository. I've done this in the past and had no problems but now I am
>>> having dificulties pushing the initial commit to gitosis.qgis.org
>>> In redmine I created the repository and added my SSH key. Then I
>>> initialized my git repo locally and added the remote repo using the URL
>>> that redmine gave me. I did my first commit and now I want to push it to
>>> the remote repository. I keep getting an error about not having permission
>>> when I input my password.
>>> Must I first upload the code and ask for approval in order to get the
>>> remote repository created?
>>> The plugin's name is 'Conefor inputs'.
>> The first sign the something isn't right is if gitosis asks you for a
>> password. It uses ssh keys which at most will ask you to unlock your local
>> passphrase for the key in use.
>> Can you please list the git commands you ran.
>> Also what's the output of:
>> git remote -v
>> Thanks,
>> Alex
