[Qgis-developer] SIP API Update
Etienne Tourigny etourigny.dev at gmail.com
Tue Jun 4 12:06:41 PDT 2013
How do we handle translated strings with arguments? QString::arg() is not
available.
Not sure if the following would work? The string syntax is slightly
different and would require re-translation, but at least works in English
before:
self.tr( "%1 not created." ).arg( outFn )
after:
self.tr( "%s not created." ) % outFn
  File
"/home/softdev/share/qgis/python/plugins/GdalTools/tools/widgetPluginBase.py",
line 120, in finished
    QMessageBox.warning(self, self.tr( "Warning" ), self.tr( "%1 not
created." ).arg( outFn ) )
AttributeError: 'unicode' object has no attribute 'arg'
On Thu, May 30, 2013 at 3:12 AM, Nathan Woodrow <madmanwoo at gmail.com> wrote:
> Hey all,
> I have decided to manage the SIP API update process so that we can have it
> done by 2.0.  This is an important update as leaving it for later will
> break every plugin yet again at later date which just leaves a really bad
> taste for people to deal with. A few plugin authors have already expressed
> that they would not be impressed having to do another major update again in
> the future. And I agree.
> So having said that this is the current plan:
> - I have created a branch with the SIP API v2 update
>  - Update all the core plugins in the sipapi-udate[0] branch over the next
> couple of days
> -  Merge into master
> I couldn't update all the core plugins myself BUT it would be a lot easier
> if I could call on the plugin authors to run though their own code and do
> the quick update.  The risk of me doing it is that I might break something
> and not know it.  You know your code best so the help would be greatly
> appreciated.
> I updated most of the console code and Salvatore has already cleaned the
> rest up for me so that is one thing out of the way.
> And here comes the kicker: I would like to do this as quickly as we can so
> to reduce the gap between master and the branch.  The sooner we merge it to
> master the sooner we can open it to wider testing, but I don't expect to
> run into any major issues when we do.
> If you are not aware of what benefits the SIP API update will bring here
> is a quick example:
> Before:
> >>> str(yourlineedit.text().toString())
> 'Hello World'
> >>> feature["column"].toInt()[0]
> 100
> After
> >>> yourlineedit.text()
> 'Hello World'
> >>> feature["column"]
> 1000
> It will make life for us and plugin authors a hell of a lot easier.
> I have put together a quick guide[1] with some examples.  It is open edit
> so feel free to add any notes you have. It might be good to turn it into a
> plugin translate guide for future plugin authors moving to 2.0.
> Regards,
> Nathan
> [0] https://github.com/qgis/Quantum-GIS/tree/sipapi-update
> [1]
> https://docs.google.com/document/d/1S85DMEC71AOzTkF1_EpnF0dhVb2On2EVq4E5s1EXoNM/edit?usp=sharing
> Qgis-developer mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20130604/2b5e2c4c/attachment.html>
