[Qgis-developer] SIP API Update
Etienne Tourigny
etourigny.dev at gmail.com
Thu Jun 6 06:52:42 PDT 2013
On Thu, Jun 6, 2013 at 9:46 AM, Nathan Woodrow <madmanwoo at gmail.com> wrote:
> Hey all,
> Would I be able to get an update on where everyone is at with updating the
> core plugins. I have started updating the plugin installer and should have
> that done tomorrow.
I have fixed a few of the GdalTools algorithms (and most of the generic
code that is used by all algos), but quite a few remain. Most of the work
left is rather simple, i.e. argument processing and string comparison.
But I don't have much time until next week. If someone can step in it would
be great.
Etienne
> - Nathan
> On Wed, Jun 5, 2013 at 7:09 AM, Etienne Tourigny <etourigny.dev at gmail.com>wrote:
>> On Tue, Jun 4, 2013 at 3:40 PM, Etienne Tourigny <etourigny.dev at gmail.com
>> > wrote:
>>> I just ran into another problem... how do you pass a list (of strings)
>>> to a QT function which requires a QStringList (which is not available
>>> anymore).
>>> File
>>> "/home/softdev/share/qgis/python/plugins/GdalTools/tools/GdalTools_utils.py",
>>> line 208, in getRasterFiles
>>> workDir.setNameFilters( filter )
>>> TypeError: QDir.setNameFilters(QStringList): argument 1 has unexpected
>>> type 'list'
>> never mind... it works now.
>>> On Thu, May 30, 2013 at 3:12 AM, Nathan Woodrow <madmanwoo at gmail.com>wrote:
>>>> Hey all,
>>>> I have decided to manage the SIP API update process so that we can have
>>>> it done by 2.0. This is an important update as leaving it for later will
>>>> break every plugin yet again at later date which just leaves a really bad
>>>> taste for people to deal with. A few plugin authors have already expressed
>>>> that they would not be impressed having to do another major update again in
>>>> the future. And I agree.
>>>> So having said that this is the current plan:
>>>> - I have created a branch with the SIP API v2 update
>>>> - Update all the core plugins in the sipapi-udate[0] branch over the
>>>> next couple of days
>>>> - Merge into master
>>>> I couldn't update all the core plugins myself BUT it would be a lot
>>>> easier if I could call on the plugin authors to run though their own code
>>>> and do the quick update. The risk of me doing it is that I might break
>>>> something and not know it. You know your code best so the help would be
>>>> greatly appreciated.
>>>> I updated most of the console code and Salvatore has already cleaned
>>>> the rest up for me so that is one thing out of the way.
>>>> And here comes the kicker: I would like to do this as quickly as we can
>>>> so to reduce the gap between master and the branch. The sooner we merge it
>>>> to master the sooner we can open it to wider testing, but I don't expect to
>>>> run into any major issues when we do.
>>>> If you are not aware of what benefits the SIP API update will bring
>>>> here is a quick example:
>>>> Before:
>>>> >>> str(yourlineedit.text().toString())
>>>> 'Hello World'
>>>> >>> feature["column"].toInt()[0]
>>>> 100
>>>> After
>>>> >>> yourlineedit.text()
>>>> 'Hello World'
>>>> >>> feature["column"]
>>>> 1000
>>>> It will make life for us and plugin authors a hell of a lot easier.
>>>> I have put together a quick guide[1] with some examples. It is open
>>>> edit so feel free to add any notes you have. It might be good to turn it
>>>> into a plugin translate guide for future plugin authors moving to 2.0.
>>>> Regards,
>>>> Nathan
>>>> [0] https://github.com/qgis/Quantum-GIS/tree/sipapi-update
>>>> [1]
>>>> https://docs.google.com/document/d/1S85DMEC71AOzTkF1_EpnF0dhVb2On2EVq4E5s1EXoNM/edit?usp=sharing
>>>> _______________________________________________
>>>> Qgis-developer mailing list
>>>> Qgis-developer at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20130606/44ddf339/attachment.html>
