[Qgis-developer] the new Plugin Manager
Marco Hugentobler marco.hugentobler at sourcepole.ch
Wed Jun 5 00:09:37 PDT 2013
Hi Nathan
I'm away today and can merge earliest late evening or probably in the
morning.
Alternatively, to not block your progress with the new API, you could do
the plugin manager merge / SIP update / python part update and the const
things can be easily added later.
Regards,
Marco
On 05.06.2013 08:53, Nathan Woodrow wrote:
> Marco,
> As Borys is away would you be able to merge it tonight.  I can then
> merge the SIP update once that is done, just need to check the status.
>  I'll take care of updating the python part of the installer to the
> new API once it's merged into master.
> Regards,
> Nathan
> On Wed, Jun 5, 2013 at 4:48 PM, Marco Hugentobler
> <marco.hugentobler at sourcepole.ch
> <mailto:marco.hugentobler at sourcepole.ch>> wrote:
>     Hi Borys
>     I tested the newpluginmanager branch and I must say the new plugin
>     manager / installer is really a great user experience. And it is
>     good that the plugin manager also works without the python
>     bindings (handy e.g. in the server case).
>     Codewise, I have few suggestion on detail level:
>     QgsPluginRegistry: isLoaded(), isPythonPlugin(),
>     isPluginCompatible() can be const
>     QgsPluginManager: pluginMetadata() returns a pointer to the map.
>     This function should be const and return either const pointer or a
>     copy (kind of similar issue like recently with the layer registry)
>     It might be worth thinking if QgsPluginRegistry should be in core
>     and accessible by third party apps / plugins. Like that it would
>     e.g. be possible to use functions from one plugin in another and
>     load the required plugin if not already there. The plugin registry
>     could also emit an unload signal to notify the dependent plugin.
>     I'm not 100% sure it is a good idea, but maybe it would be handy
>     for sextante (e.g. WPS plugin requires a loaded sextante)?
>     All in all great work. I'm proposing that you merge the branch to
>     master.
>     Regards,
>     Marco
>     On 27.05.2013 14:23, Borys Jurgiel wrote:
>         Hi All,
>         The new manager is ready. Here is a screenshot for impatient
>         ones :)
>         http://tmp.borysjurgiel.pl/manager4.png
>         The code is in a branch "newmanager":
>         http://hub.qgis.org/projects/quantum-gis/repository/revisions/5ee09d362148c411047a0fc7bc22679d9989f771
>         As it affects a number of classes, please review the
>         architecture summary
>         below and if there is no veto, it's ready to be merged to
>         master. Otherewise I'll
>         make requested changes before merging.
>         *QgsPluginItem*
>         Removed. It only used in the old manager and wasn't usefull
>         anymore.
>         *QgsDetailedItemData, QgsDetailedItemDelegate and
>         QgsDetailedItemWidget*
>         Untouched. It was used in the old manager and Grass Plugin,
>         now it's used
>         exclusively by Grass Plugin.
>         *QgsPluginMedatadata*
>         Untouched, however I propose to rename it to QgsPluginItem or
>         QgsPluginRegistryItem
>         for consistency. It's only used in QgsPluginRegistry and it
>         mainly conatains
>         pointers to loaded plugins instances, while its name may imply
>         a rich metadata
>         map. If some day during QGIS 2.x lifetime the Manager will
>         need a separate class
>         for storing rich metadata (now QMap is enough), and it would
>         be nice to use this name.
>         *QgsPluginRegistry*
>         Info: This class is a registry for instances of lodaded
>         plugins. It has nothing to to
>         with metadata and it works independently from the manager,
>         just by restoring
>         session plugins from QSettings. Manager only calls its method
>         to load and unload plugins.
>         Small change: as it already had methods loadCppPlugin() and
>         loadPythonPlugin(),
>         I've added also unloadCppPlugin() and unloadPythonPlugin() too
>         keep the
>         loading/unloading stuff in one place.
>         Diff:
>         http://hub.qgis.org/projects/quantum-gis/repository/revisions/5ee09d362148c411047a0fc7bc22679d9989f771/diff/src/app/qgspluginregistry.h
>         http://hub.qgis.org/projects/quantum-gis/repository/revisions/5ee09d362148c411047a0fc7bc22679d9989f771/diff/src/app/qgspluginregistry.cpp
>         *QgsPluginManager*
>         Completely rewritten and moved to src/app/pluginmanager/
>         subdirectory
>         class for the dialog window. Important facts:
>         1) It keeps plugin metadata registry just in nested QMap:
>         QMap< QString, QMap<QString,QString> > mPlugins;
>         where the first key is library/module basename, and the second
>         one is attribute
>         name. There was no need to create a separate class for storing
>         metadata,
>         however, some day it may become convinient to create a class
>         called QgsPluginMedatadata.
>         For this reason I propose to rename the current
>         QgsPluginMedatadata
>         (what actually has nothing to do with metadata) before
>         releasing QGIS 2.0.
>         The list of used attributes is provided in the "metadata" file
>         and it's an unification
>         of existing fields from repository xml, metadata.txt, the old
>         installer and c++ plugins.
>         QgsPluginManager populates this field (let's call it metadata
>         registry) with
>         c++ plugins when the window is opened. On the contrary, Python
>         plugins
>         are handled on Python's side and they are appended to mPlugins
>         by API.
>         2) The plugin list view uses QStandardItemModel populated from
>         mPlugins
>         and also QgsPluginSortFilterProxyModel for filtering and sorting.
>         3) The html metadata browser is quite simple, and we can
>         extend it in QGIS 2.1.
>         For example, some tags can be clickable and set a new filter
>         (filter by clicked
>         author/tag/status). Also the separate buttons
>         Install/Uninstall can be
>         implemented by html "buttonsm", and the popup dialog with
>         installation progress
>         can be replaced by animated image (this way we don't freeze
>         the gui when installing).
>         Code:
>         http://hub.qgis.org/projects/quantum-gis/repository/revisions/5ee09d362148c411047a0fc7bc22679d9989f771/entry/src/app/pluginmanager/qgspluginmanager.h
>         http://hub.qgis.org/projects/quantum-gis/repository/revisions/5ee09d362148c411047a0fc7bc22679d9989f771/entry/src/app/pluginmanager/qgspluginmanager.cpp
>         *QgsPluginSortFilterProxyModel*
>         New class: just a sort-filter proxy for the metadata.
>         Filtering is done by status
>         in the left list as well as name/description/tags/author in
>         the filter input line.
>         Sorting is done by rightclicking on the list. Foltering and
>         sorting is based
>         on a few user data roles. I tried to read necessary data from
>         mPlugins everytime,
>         but it affected the performance too much.
>         Code:
>         http://hub.qgis.org/projects/quantum-gis/repository/revisions/5ee09d362148c411047a0fc7bc22679d9989f771/entry/src/app/pluginmanager/qgspluginsortfilterproxymodel.h
>         http://hub.qgis.org/projects/quantum-gis/repository/revisions/5ee09d362148c411047a0fc7bc22679d9989f771/entry/src/app/pluginmanager/qgspluginsortfilterproxymodel.cpp
>         *QgsAppPluginManagerInterface, QgsPluginManagerInterface and
>         SIP binding*
>         New classes: just the interface to QgsPluginManager. Is's
>         exactly based
>         on the existing Qgs(App)LegendInterface
>         Code:
>         http://hub.qgis.org/projects/quantum-gis/repository/revisions/5ee09d362148c411047a0fc7bc22679d9989f771/entry/python/gui/qgspluginmanagerinterface.sip
>         http://hub.qgis.org/projects/quantum-gis/repository/revisions/5ee09d362148c411047a0fc7bc22679d9989f771/entry/src/gui/qgspluginmanagerinterface.h
>         http://hub.qgis.org/projects/quantum-gis/repository/revisions/5ee09d362148c411047a0fc7bc22679d9989f771/entry/src/gui/qgspluginmanagerinterface.cpp
>         http://hub.qgis.org/projects/quantum-gis/repository/revisions/5ee09d362148c411047a0fc7bc22679d9989f771/entry/src/app/pluginmanager/qgsapppluginmanagerinterface.h
>         http://hub.qgis.org/projects/quantum-gis/repository/revisions/5ee09d362148c411047a0fc7bc22679d9989f771/entry/src/app/pluginmanager/qgsapppluginmanagerinterface.cpp
>         QgisApp
>         Small change: initialize the QgsPluginManager and Python module
>         pyplugin_installer in the constructor. Only open the
>         QgsPluginManager window
>         when called from the main menu.
>         Diff:
>         http://hub.qgis.org/projects/quantum-gis/repository/revisions/5ee09d362148c411047a0fc7bc22679d9989f771/diff/src/app/qgisapp.h
>         http://hub.qgis.org/projects/quantum-gis/repository/revisions/5ee09d362148c411047a0fc7bc22679d9989f771/diff/src/app/qgisapp.cpp
>         QgisAppInterface and QgisInterface and SIP binding
>         Small change: instantiate Qgs(App)PluginManagerInterface
>         exactly the same way as Qgs(App)LegendInterface
>         Diff:
>         http://hub.qgis.org/projects/quantum-gis/repository/revisions/5ee09d362148c411047a0fc7bc22679d9989f771/diff/src/app/qgisappinterface.h
>         http://hub.qgis.org/projects/quantum-gis/repository/revisions/5ee09d362148c411047a0fc7bc22679d9989f771/diff/src/app/qgisappinterface.cpp
>         pyplugin_installer Python module
>         New python module in python/pyplugin_installer. It contains
>         just slightly refactored
>         code of the old plugin_installer plugin and provides backend
>         for handling Python
>         plugis, e.g.: fetching remote repositories, loading installed
>         plugin metadata, finding
>         upgradeable plugins, (un)installing python plugins etc. It's
>         methods are called from
>         QgsPluginManager and it calls QgsPluginManager methods via
>         QgsPluginManagerInterface.
>         Code:
>         http://hub.qgis.org/projects/quantum-gis/repository/revisions/5ee09d362148c411047a0fc7bc22679d9989f771/show/python/pyplugin_installer
>         _______________________________________________
>         Qgis-developer mailing list
>         Qgis-developer at lists.osgeo.org
>         <mailto:Qgis-developer at lists.osgeo.org>
>         http://lists.osgeo.org/mailman/listinfo/qgis-developer
>     Dr. Marco Hugentobler
>     Sourcepole -  Linux & Open Source Solutions
>     Weberstrasse 5, CH-8004 Zürich, Switzerland
>     <mailto:marco.hugentobler at sourcepole.ch> http://www.sourcepole.ch
>     Technical Advisor QGIS Project Steering Committee
>     Qgis-developer at lists.osgeo.org <mailto:Qgis-developer at lists.osgeo.org>
marco.hugentobler at sourcepole.ch http://www.sourcepole.ch
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20130605/6abefcef/attachment-0001.html>
