[Qgis-developer] the new Plugin Manager
Nathan Woodrow madmanwoo at gmail.com
Wed Jun 5 00:12:45 PDT 2013
Marco,
I can merge the new plugin installer tonight if your happy with that.  I'm
not sure I will merge the SIP stuff in just yet but I will review and see
where to go from there.
Regards,
Nathan
On Wed, Jun 5, 2013 at 5:09 PM, Marco Hugentobler <
marco.hugentobler at sourcepole.ch> wrote:
>  Hi Nathan
> I'm away today and can merge earliest late evening or probably in the
> morning.
> Alternatively, to not block your progress with the new API, you could do
> the plugin manager merge / SIP update / python part update and the const
> things can be easily added later.
> Regards,
> Marco
> On 05.06.2013 08:53, Nathan Woodrow wrote:
> Marco,
>  As Borys is away would you be able to merge it tonight.  I can then
> merge the SIP update once that is done, just need to check the status.
>  I'll take care of updating the python part of the installer to the new API
> once it's merged into master.
>  Regards,
> Nathan
> On Wed, Jun 5, 2013 at 4:48 PM, Marco Hugentobler <
>> Hi Borys
>> I tested the newpluginmanager branch and I must say the new plugin
>> manager / installer is really a great user experience. And it is good that
>> the plugin manager also works without the python bindings (handy e.g. in
>> the server case).
>> Codewise, I have few suggestion on detail level:
>> QgsPluginRegistry: isLoaded(), isPythonPlugin(), isPluginCompatible() can
>> be const
>> QgsPluginManager: pluginMetadata() returns a pointer to the map. This
>> function should be const and return either const pointer or a copy (kind of
>> similar issue like recently with the layer registry)
>> It might be worth thinking if QgsPluginRegistry should be in core and
>> accessible by third party apps / plugins. Like that it would e.g. be
>> possible to use functions from one plugin in another and load the required
>> plugin if not already there. The plugin registry could also emit an unload
>> signal to notify the dependent plugin. I'm not 100% sure it is a good idea,
>> but maybe it would be handy for sextante (e.g. WPS plugin requires a loaded
>> sextante)?
>> All in all great work. I'm proposing that you merge the branch to master.
>> Regards,
>> Marco
>> On 27.05.2013 14:23, Borys Jurgiel wrote:
>>> Hi All,
>>> The new manager is ready. Here is a screenshot for impatient ones :)
>>> http://tmp.borysjurgiel.pl/manager4.png
>>> The code is in a branch "newmanager":
>>> http://hub.qgis.org/projects/quantum-gis/repository/revisions/5ee09d362148c411047a0fc7bc22679d9989f771
>>> As it affects a number of classes, please review the architecture summary
>>> below and if there is no veto, it's ready to be merged to master.
>>> Otherewise I'll
>>> make requested changes before merging.
>>> *QgsPluginItem*
>>> Removed. It only used in the old manager and wasn't usefull anymore.
>>> *QgsDetailedItemData, QgsDetailedItemDelegate and QgsDetailedItemWidget*
>>> Untouched. It was used in the old manager and Grass Plugin, now it's used
>>> exclusively by Grass Plugin.
>>> *QgsPluginMedatadata*
>>> Untouched, however I propose to rename it to QgsPluginItem or
>>> QgsPluginRegistryItem
>>> for consistency. It's only used in QgsPluginRegistry and it mainly
>>> conatains
>>> pointers to loaded plugins instances, while its name may imply a rich
>>> metadata
>>> map. If some day during QGIS 2.x lifetime the Manager will need a
>>> separate class
>>> for storing rich metadata (now QMap is enough), and it would be nice to
>>> use this name.
>>> *QgsPluginRegistry*
>>> Info: This class is a registry for instances of lodaded plugins. It has
>>> nothing to to
>>> with metadata and it works independently from the manager, just by
>>> restoring
>>> session plugins from QSettings. Manager only calls its method to load
>>> and unload plugins.
>>> Small change: as it already had methods loadCppPlugin() and
>>> loadPythonPlugin(),
>>> I've added also unloadCppPlugin() and unloadPythonPlugin() too keep the
>>> loading/unloading stuff in one place.
>>> Diff:
>>> http://hub.qgis.org/projects/quantum-gis/repository/revisions/5ee09d362148c411047a0fc7bc22679d9989f771/diff/src/app/qgspluginregistry.h
>>> http://hub.qgis.org/projects/quantum-gis/repository/revisions/5ee09d362148c411047a0fc7bc22679d9989f771/diff/src/app/qgspluginregistry.cpp
>>> *QgsPluginManager*
>>> Completely rewritten and moved to src/app/pluginmanager/ subdirectory
>>> class for the dialog window. Important facts:
>>> 1) It keeps plugin metadata registry just in nested QMap:
>>> QMap< QString, QMap<QString,QString> >   mPlugins;
>>> where the first key is library/module basename, and the second one is
>>> attribute
>>> name. There was no need to create a separate class for storing metadata,
>>> however, some day it may become convinient to create a class called
>>> QgsPluginMedatadata.
>>> For this reason I propose to rename the current QgsPluginMedatadata
>>> (what actually has nothing to do with metadata) before releasing QGIS
>>> 2.0.
>>> The list of used attributes is provided in the "metadata" file and it's
>>> an unification
>>> of existing fields from repository xml, metadata.txt, the old installer
>>> and c++ plugins.
>>> QgsPluginManager populates this field (let's call it metadata registry)
>>> with
>>> c++ plugins when the window is opened. On the contrary, Python plugins
>>> are handled on Python's side and they are appended to mPlugins by API.
>>> 2) The plugin list view uses QStandardItemModel populated from mPlugins
>>> and also QgsPluginSortFilterProxyModel for filtering and sorting.
>>> 3) The html metadata browser is quite simple, and we can extend it in
>>> QGIS 2.1.
>>> For example, some tags can be clickable and set a new filter (filter by
>>> clicked
>>> author/tag/status). Also the separate buttons Install/Uninstall can be
>>> implemented by html "buttonsm", and the popup dialog with installation
>>> progress
>>> can be replaced by animated image (this way we don't freeze the gui when
>>> installing).
>>> Code:
>>> http://hub.qgis.org/projects/quantum-gis/repository/revisions/5ee09d362148c411047a0fc7bc22679d9989f771/entry/src/app/pluginmanager/qgspluginmanager.h
>>> http://hub.qgis.org/projects/quantum-gis/repository/revisions/5ee09d362148c411047a0fc7bc22679d9989f771/entry/src/app/pluginmanager/qgspluginmanager.cpp
>>> *QgsPluginSortFilterProxyModel*
>>> New class: just a sort-filter proxy for the metadata. Filtering is done
>>> by status
>>> in the left list as well as name/description/tags/author in the filter
>>> input line.
>>> Sorting is done by rightclicking on the list. Foltering and sorting is
>>> based
>>> on a few user data roles. I tried to read necessary data from mPlugins
>>> everytime,
>>> but it affected the performance too much.
>>> Code:
>>> http://hub.qgis.org/projects/quantum-gis/repository/revisions/5ee09d362148c411047a0fc7bc22679d9989f771/entry/src/app/pluginmanager/qgspluginsortfilterproxymodel.h
>>> http://hub.qgis.org/projects/quantum-gis/repository/revisions/5ee09d362148c411047a0fc7bc22679d9989f771/entry/src/app/pluginmanager/qgspluginsortfilterproxymodel.cpp
>>> *QgsAppPluginManagerInterface, QgsPluginManagerInterface and SIP binding*
>>> New classes: just the interface to QgsPluginManager. Is's exactly based
>>> on the existing Qgs(App)LegendInterface
>>> Code:
>>> http://hub.qgis.org/projects/quantum-gis/repository/revisions/5ee09d362148c411047a0fc7bc22679d9989f771/entry/python/gui/qgspluginmanagerinterface.sip
>>> http://hub.qgis.org/projects/quantum-gis/repository/revisions/5ee09d362148c411047a0fc7bc22679d9989f771/entry/src/gui/qgspluginmanagerinterface.h
>>> http://hub.qgis.org/projects/quantum-gis/repository/revisions/5ee09d362148c411047a0fc7bc22679d9989f771/entry/src/gui/qgspluginmanagerinterface.cpp
>>> http://hub.qgis.org/projects/quantum-gis/repository/revisions/5ee09d362148c411047a0fc7bc22679d9989f771/entry/src/app/pluginmanager/qgsapppluginmanagerinterface.h
>>> http://hub.qgis.org/projects/quantum-gis/repository/revisions/5ee09d362148c411047a0fc7bc22679d9989f771/entry/src/app/pluginmanager/qgsapppluginmanagerinterface.cpp
>>> QgisApp
>>> Small change: initialize the QgsPluginManager and Python module
>>> pyplugin_installer in the constructor. Only open the QgsPluginManager
>>> window
>>> when called from the main menu.
>>> Diff:
>>> http://hub.qgis.org/projects/quantum-gis/repository/revisions/5ee09d362148c411047a0fc7bc22679d9989f771/diff/src/app/qgisapp.h
>>> http://hub.qgis.org/projects/quantum-gis/repository/revisions/5ee09d362148c411047a0fc7bc22679d9989f771/diff/src/app/qgisapp.cpp
>>> QgisAppInterface and QgisInterface and SIP binding
>>> Small change: instantiate Qgs(App)PluginManagerInterface
>>> exactly the same way as Qgs(App)LegendInterface
>>> Diff:
>>> http://hub.qgis.org/projects/quantum-gis/repository/revisions/5ee09d362148c411047a0fc7bc22679d9989f771/diff/src/app/qgisappinterface.h
>>> http://hub.qgis.org/projects/quantum-gis/repository/revisions/5ee09d362148c411047a0fc7bc22679d9989f771/diff/src/app/qgisappinterface.cpp
>>> pyplugin_installer Python module
>>> New python module in python/pyplugin_installer. It contains just
>>> slightly refactored
>>> code of the old plugin_installer plugin and provides backend for
>>> handling Python
>>> plugis, e.g.: fetching remote repositories, loading installed plugin
>>> metadata, finding
>>> upgradeable plugins, (un)installing python plugins etc. It's methods are
>>> called from
>>> QgsPluginManager and it calls QgsPluginManager methods via
>>> QgsPluginManagerInterface.
>>> Code:
>>> http://hub.qgis.org/projects/quantum-gis/repository/revisions/5ee09d362148c411047a0fc7bc22679d9989f771/show/python/pyplugin_installer
>>> Qgis-developer mailing list
>>> Qgis-developer at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Dr. Marco Hugentobler
>> Sourcepole -  Linux & Open Source Solutions
>> Weberstrasse 5, CH-8004 Zürich, Switzerland
>> marco.hugentobler at sourcepole.ch http://www.sourcepole.ch
>> Technical Advisor QGIS Project Steering Committee
> Weberstrasse 5, CH-8004 Zürich, Switzerlandmarco.hugentobler at sourcepole.ch http://www.sourcepole.ch
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20130605/935e61a6/attachment-0001.html>
