[Qgis-developer] Oracle provider tests
Andreas Neumann a.neumann at carto.net
Fri Jun 7 07:09:25 PDT 2013
Hi René,
Did you get the table listing?
If yes, you have to choose the geometry type and the primary key column
- otherwise you cannot select and add the layer. Same with Postgis, but
with Postgis there is some good autodetection (depending on the QGIS
version).
Andreas
Am 07.06.2013 16:07, schrieb rldhont:
> Hi Paolo,
> I would like to know if you have some trouble to select Oracle layer in
> the Oracle connection dialog ?
> I have tested the Oracle Connection for a customer and I didn't be able
> to add Oracle Layer to my project because I can't select it.
> Regards,
> René-Luc D'Hont
> Le 07/06/2013 10:15, Paolo Cavallini a écrit :
> Il 06/06/2013 10:50, Paolo Cavallini ha scritto:
>>>> Il 06/06/2013 10:03, Paolo Cavallini ha scritto:
>>>>> This happens with multipolygons, not with points.
>>>> nor with lines.
>>>> We also noticed that one extra line is listed for most or all geom
>>>> tables, without the type of geometry. Also, many tables have both a
>>>> polygon and a multipolygon layer (or line and multiline).
>>>> Is this a known phenomenon? Any explanation?
> This seems to be related to the (possibly messy) way the tables have
> been managed, so
> probably a local phenomenon.
> All the best.
> -- Paolo Cavallini - Faunalia
> www.faunalia.eu
> Full contact details at www.faunalia.eu/pc
> Nuovi corsi QGIS e PostGIS: http://www.faunalia.it/calendario
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
