[Qgis-developer] Oracle provider tests
rldhont
rldhont at gmail.com
Fri Jun 7 07:12:25 PDT 2013
Hi Andreas,
Thanks for this information.
I have the table listing but I don't that I have to choose the geometry
type and the primary key column. Do I have to select the SRS ?
René-Luc D'Hont
Le 07/06/2013 16:09, Andreas Neumann a écrit :
> Hi René,
> Did you get the table listing?
> If yes, you have to choose the geometry type and the primary key column
> - otherwise you cannot select and add the layer. Same with Postgis, but
> with Postgis there is some good autodetection (depending on the QGIS
> version).
> Andreas
> Am 07.06.2013 16:07, schrieb rldhont:
>> Hi Paolo,
>> I would like to know if you have some trouble to select Oracle layer in
>> the Oracle connection dialog ?
>> I have tested the Oracle Connection for a customer and I didn't be able
>> to add Oracle Layer to my project because I can't select it.
>> Regards,
>> René-Luc D'Hont
>> Le 07/06/2013 10:15, Paolo Cavallini a écrit :
>> Il 06/06/2013 10:50, Paolo Cavallini ha scritto:
>>>>> Il 06/06/2013 10:03, Paolo Cavallini ha scritto:
>>>>>> This happens with multipolygons, not with points.
>>>>> nor with lines.
>>>>> We also noticed that one extra line is listed for most or all geom
>>>>> tables, without the type of geometry. Also, many tables have both a
>>>>> polygon and a multipolygon layer (or line and multiline).
>>>>> Is this a known phenomenon? Any explanation?
>> This seems to be related to the (possibly messy) way the tables have
>> been managed, so
>> probably a local phenomenon.
>> All the best.
>> -- Paolo Cavallini - Faunalia
>> www.faunalia.eu
>> Full contact details at www.faunalia.eu/pc
>> Nuovi corsi QGIS e PostGIS: http://www.faunalia.it/calendario
>>> Qgis-developer mailing list
>>> Qgis-developer at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
