[Qgis-developer] SIP API Update merged. Attention plugin authors
Richard Duivenvoorde
rdmailings at duif.net
Sun Jun 9 00:52:48 PDT 2013
On 08-06-13 13:35, Nathan Woodrow wrote:
> Hey all,
> The new SIP API has been merged now. There are still a few things to
> clean up in some of the core plugins but it is merged for wider testing.
> I don't expect to find any major issues.
Cool, THANKS!
> I would recommend creating a branch in git with your new 2.0 version and
> be ready to upload it when I give the go ahead.
Is it not 'better' to branch your old version in the 1.8.x branch, and
do further work in master (for future releases)?
If I understand correctly, there is some (more) work and clean up
possible for all 2.0 plugins:
- sip2 stuff Nathans lists in https://gist.github.com/NathanW2/5734767
(from which the new SIGNAL stuff is most scary for me)
- remove old symbology related code, because 2.0 has only new symbology
- remove the 1.8/2.0 switches that were needed for being able to run
both api-versions (not needed anymore because a 2.0 version is now
incompatible with 1.8).
right?
Regards,
