[Qgis-developer] Can we remove old labeling from the UI
Borys Jurgiel lists at borysjurgiel.pl
Sun Jun 9 03:47:11 PDT 2013
The only thing I *REALLY* miss in the new labelling is an optional FAST method
to put labels just in poligon centroids with ommiting any expensive collision
algorithms. When just browsing data the speed is priority, I don't need
beautiful map, I need to FAST put ANY labels to see what is in polygons.
Unless it's not available in the new labelling, we make a regression, removing
one of the most fundamental features. Please correct me if I'm missed some PAL
option that I can disable to achieve a significant boost.
Dnia niedziela, 9 czerwca 2013 o 12:13:01 MORREALE Jean Roc napisał(a):
> What is the status ? Are we going to keep a deprecated label tab for the
> next 3 years ?
> Le 26/05/2013 14:37, Nathan Woodrow a écrit :
> > Can we finally remove the old label UI from the layer properties dialog?
> >   Could we remove it by default and just enable it for old project that
> > have old labels defined.
> > - Nathan
> Qgis-developer mailing list
