[Qgis-developer] configuration lost when running 2.0
Werner Macho
werner.macho at gmail.com
Wed Jun 12 06:29:19 PDT 2013
Hi!
To my knowledge this is only for having 1.x and 2.x versions running
parallel on the same computer .. (If there are any new issues with the new
version or you need the old because some plugins you really need are not
updated)
But I think it will be possible to copy those seetings over from the old
configuration file .. Though i never tried it ..
regards
Werner
On Wed, Jun 12, 2013 at 3:24 PM, Sandro Santilli <strk at keybit.net> wrote:
> I was surprised by not finding my postgresql connections in the pull-down
> menu when starting qgis-2.0 (master) from the build dir. I'm pretty sure
> it used to work last time I'v built it.
> NathanW told me this is due to a change in the configuration path, from
> .qgis to .qgis2, and I'm wondering why this forced reset is needed.
> I don't know what else is in those configs, but this specific setting
> I'm after is really annoying to loose. It'd be like loosing bookmarks
> when upgrading a web browser from one version to another.
> So, what's the rationale for changing that name, thus using a completely
> separate configuration ?
> --strk;
> Qgis-developer mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20130612/45827434/attachment.html>
