[Qgis-developer] configuration lost when running 2.0
Nathan Woodrow madmanwoo at gmail.com
Wed Jun 12 06:39:25 PDT 2013
This is to allow the running of 1.8 and 2.0.
On windows, because I don't know where it is in linux, the settings are
stored in:
For 1.8
HKEY_CURRENT_USER\Software\QuantumGIS\QGIS
For 2.0:
HKEY_CURRENT_USER\Software\QGIS\QGIS2
1) For the re-banding we did
2) To allow 1.8 and 2.0 to run on the same machine without overriding a
persons 1.8 setup.
You lost the settings because settings are not auto transfered when QGIS
starts. It could be done but no one has done it.  This is the same reason
we have a .qgis and .qgis2 folder.  The plugins can conflict so we have to
keep them apart, the symbol library format has also changed,
- Nathan
On Wed, Jun 12, 2013 at 11:24 PM, Sandro Santilli <strk at keybit.net> wrote:
> I was surprised by not finding my postgresql connections in the pull-down
> menu when starting qgis-2.0 (master) from the build dir. I'm pretty sure
> it used to work last time I'v built it.
> NathanW told me this is due to a change in the configuration path, from
> .qgis to .qgis2, and I'm wondering why this forced reset is needed.
> I don't know what else is in those configs, but this specific setting
> I'm after is really annoying to loose. It'd be like loosing bookmarks
> when upgrading a web browser from one version to another.
> So, what's the rationale for changing that name, thus using a completely
> separate configuration ?
> --strk;
> Qgis-developer mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20130612/545c6a8a/attachment.html>
