[Qgis-developer] configuration lost when running 2.0
Matthias Kuhn
matthias.kuhn at gmx.ch
Wed Jun 12 07:00:12 PDT 2013
On Linux the settings are in ~/.config/QGIS/QGIS2.conf
To get the latest (if you've been running QGIS 2.0 already two weeks
ago) copy them from ~/.config/QuantumGIS/QGIS2.conf
If you have not been using master so far (I know that you did, but
maybe others, and especially users upgrading once stable) copy from
~/.config/QuantumGIS/QGIS.conf
You've lost the config twice due to renaming from QuantumGIS to QGIS
once:
~/.config/QuantumGIS/QGIS.conf > ~/.config/QuantumGIS/QGIS2.conf
and again:
~/.config/QuantumGIS/QGIS2.conf > ~/.config/QGIS/QGIS2.conf
On Mit 12 Jun 2013 15:39:25 CEST, Nathan Woodrow wrote:
> This is to allow the running of 1.8 and 2.0.
> On windows, because I don't know where it is in linux, the settings
> are stored in:
> For 1.8
> HKEY_CURRENT_USER\Software\QuantumGIS\QGIS
> For 2.0:
> HKEY_CURRENT_USER\Software\QGIS\QGIS2
> 1) For the re-banding we did
> 2) To allow 1.8 and 2.0 to run on the same machine without overriding
> a persons 1.8 setup.
> You lost the settings because settings are not auto transfered when
> QGIS starts. It could be done but no one has done it. This is the
> same reason we have a .qgis and .qgis2 folder. The plugins can
> conflict so we have to keep them apart, the symbol library format has
> also changed,
> - Nathan
> On Wed, Jun 12, 2013 at 11:24 PM, Sandro Santilli <strk at keybit.net
> <mailto:strk at keybit.net>> wrote:
> I was surprised by not finding my postgresql connections in the
> pull-down
> menu when starting qgis-2.0 (master) from the build dir. I'm
> pretty sure
> it used to work last time I'v built it.
> NathanW told me this is due to a change in the configuration path,
> from
> .qgis to .qgis2, and I'm wondering why this forced reset is needed.
> I don't know what else is in those configs, but this specific setting
> I'm after is really annoying to loose. It'd be like loosing bookmarks
> when upgrading a web browser from one version to another.
> So, what's the rationale for changing that name, thus using a
> completely
> separate configuration ?
> --strk;
> Qgis-developer mailing list
> Qgis-developer at lists.osgeo.org <mailto:Qgis-developer at lists.osgeo.org>
