[Qgis-developer] configuration lost when running 2.0
William Kyngesburye
woklist at kyngchaos.com
Wed Jun 12 07:22:06 PDT 2013
On Jun 12, 2013, at 9:13 AM, Sandro Santilli wrote:
> On Wed, Jun 12, 2013 at 09:07:21AM -0500, William Kyngesburye wrote:
>> And --configpath isn't practical on OSX, you don't start apps from the command line on OS X, and there is no mechanism (like there is in Windows shortcuts) to add switches to an app startup.
> This sounds like an invalid argument, if what you want is two icons
> for starting the same application with two different configurations.
> Keep the web browser bookmarks in mind.
For the average user (even power user might not know how or want to mess around with it) - --configpath is not usable on OS X to set a different config path. Nobody starts QGIS or any other app on OS X from the command line. It is not possible to create a shortcut on OS X that starts an app with different startup options.
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
"Time is an illusion - lunchtime doubly so."
- Ford Prefect
