[Qgis-developer] configuration lost when running 2.0
Borys Jurgiel
lists at borysjurgiel.pl
Wed Jun 12 10:17:05 PDT 2013
Dnia środa, 12 czerwca 2013 o 18:55:23 Sandro Santilli napisał(a):
> I guess you'll want to do that only when the new config file doesn't
> exist, so it is about to be created. The user should be prompted about
> that, something like:
> "Configuration file 'XXY' was not found, do you want to start a new
> one from scratch or do you want to copy it from an old one ?"
It's obvious
> Then the tool should let you choose an old configuration to copy from.
> Ideally you'd have the known old configs in a pull down menu, but still
> allow the user to pick other locations.
There was one default location QuantumGIS/QGIS and I was thinking about a tool
for usual users to copy from there to QGIS/QGIS2.
If you store your config in a custom location, then you used to run QGIS with
--optionspath, so I don't get the idea to copy it to the default location now.
