[Qgis-developer] Openlayers plugin in 2.0 Was: QGIS 2.0 release and plugins
Anita Graser
anitagraser at gmx.at
Mon Jun 17 14:18:53 PDT 2013
Hi Richard,
If you have a - partially - working version please share it. It will serve
until the official and backwards compatible version is available.
Thanks and best wishes
Anita
On Jun 16, 2013 10:30 AM, "Richard Duivenvoorde" <rdmailings at duif.net>
wrote:
> On 16-06-13 00:39, Anita Graser wrote:
>> I'm a bit worried about not having a functioning Openlayers plugin in
>> QGIS 2.0 for two months.
>> Can someone with experience in porting plugins estimate how much work it
>> really is to make it compatible with the new API
> Hi Pirmin,
> if we manage to release 2.0 before Brighton, I agree that the Openlayers
> plugin is one plugin which should be available at 2.0 launch.
> Here locally I managed to get it running in current master (most of it,
> overview widget is not ok yet).
> But I do not want to force/stress Sourcepole or Matthias to put time in
> looking into it if they have more important things to do.
> And maybe you have (bigger/other) plans with the plugin, like a
> refactoring or upgrade of bigger parts of the code. Or maybe you know with
> QGIS 2.0 there are non sip parts that will give problems?
> I can also imagine that you really want to support only ONE plugin working
> for both sip api versions.
> But that said, I'm happy to put what I have now put on Github and ask for
> a pull request in a 2.0 branch (what I did is NOT compatible with 1.8). I'm
> also available if bugs pop up in that version in short future.
> And I agree that Brighton is then a nice place to do the 'bigger' work for
> this really important plugin.
> Regards,
> ______________________________**_________________
> Qgis-developer mailing list
> http://lists.osgeo.org/**mailman/listinfo/qgis-**developer<http://lists.osgeo.org/mailman/listinfo/qgis-developer>
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20130617/fffc30f0/attachment.html>
